  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 2.7k Views
  • PSiedTSiP
    PSiedTSiP
    Do you have a multimeter?
    spanish-rice;237125 wrote:
    • wesholeW
      wesholeW
      First, hook up a different speaker. It doesnt matter what kind of speaker or whether its even a subwoofer. Your just making sure the amp itself is putin out any sound. If it does, then it has to either be your subwoofer itself or a wire going to it. Either in the enclosure itself or to the enclosure.
      • theobliviousT
        theobliviousT
        theoblivious
        i dont have a multimeter i have a light meter (not sure if thats what its called...the thing with the light in it and a ground.)
        BOOST....to be continued
        • XJHEADX
          XJHEADX
          What turns on the amp?
          • theobliviousT
            theobliviousT
            theoblivious
            When i press the power button on my stock head unit.
            • XJHEADX
              XJHEADX
              Try by-passing that by using the amps power feed into the remote on.
              • DelSlowD
                DelSlowD
                Is it plugged in?
                • theobliviousT
                  theobliviousT
                  theoblivious
                  im sorry im a real newb...are you saying disconnect the remote wire?
                  • T
                    T
                    Trafik Jamz
                    Aside from what Wes/Bill have suggested:
                    have you messed with the fader on the deck? If so, make sure that there is signal going to whichever set of speaker outputs is providing signal to the deck.
                    Double check to make sure that somehow the speaker wire hasn't come loose on the sub as that would cause the no output possibility as well.
                    701.541.3484
                    • wesholeW
                      wesholeW
                      Ya, what we said.
                      Like I said in my first post , process of elimination. all of which will take 10 minutes to test all.... MAX. Do it all in that order.
                      • XJHEADX
                        XJHEADX
                        Just re-read your orig. post. You state the amp is getting power. Is there a light on it that turns on when you turn on the H/U? If the light turns on when you turn on H/U then it is not the remote wire. The H/U sends 12 volts via the remote wire to tell the amp to turn on. If power is not being sent on that wire the amp won't turn on. That is why I said just jumper a wire from amp feed to the remote connection to see if it would work. If that is the case then the remote feed wire is the problem. Have you tried the other suggestions?
                        • theobliviousT
                          theobliviousT
                          theoblivious
                          yes when i turn on the my HU, there is a blue light that turns on from the amp. Do i still need to jump the two wires?
                          I will get another speaker tomorrow from a friend and will test out if the sub is the problem.
                          If im understanding everything correctly:
                          1. If another speaker works, then its an issue with the sub
                          2. if it doesnt work, then its an issue with the amp. Is there any way to determine what is wrong with the amp exactly? Sorry if i am being redundant.
                          Thanks for all your help
                          • T
                            T
                            Trafik Jamz
                            I believe you bought that amp from me, correct? If so, I can try and get it fixed (under warranty if it hasn't been over a year or so)
                            701.541.3484
                            • XJHEADX
                              XJHEADX
                              No it is working correctly
                              Sub or the wires feeding it
                              You don't know if you have a audio signal reaching the amp yet. Try the new speaker with wire first.
                              Chuck is there a easy way to see if a signal is getting to the amp without putting a new amp in?
                              • MisterCMKM
                                MisterCMKM
                                Take a known good source and hook it up to the amplifier.
                                thrash;315544 wrote:
                                Ford is back :)
                                • BlueSRT0483B
                                  BlueSRT0483B
                                  BlueSRT0483
                                  Does your factory HU have RCA preouts? How is the amp knowing how to play the music? Is there a function that turns off your preouts, or whatever is used to to turn off the amp? I know on my deck, I can turn my subwoofer off, but I don't believe it turns off the amp itself.. Just stops sending the singal to power the subwoofers.
                                  Have you checked the wires on the inside of the speaker box, did any of them come loose?
                                  2004 Dodge SRT-4
                                  ...Formerly "A853"...
                                  • T
                                    T
                                    Trafik Jamz
                                    No
                                    Turns on w/ ignition...receives signal through speaker level inputs or line output converter
                                    No....except maybe the fader being set wrong
                                    Not applicable
                                    Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
                                    701.541.3484
                                    • i_like_eggsI
                                      i_like_eggsI
                                      i_like_eggs
                                      • theobliviousT
                                        theobliviousT
                                        theoblivious
                                        thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
                                        • T
                                          T
                                          Trafik Jamz
                                          Was it that long ago? Dang, thought it was last year sometime.
                                          LMK if I can be of any further help
                                          701.541.3484
                                          701.541.3484
