  4. amp has power but no sound coming out of sub
33 Posts 9 Posters 1.9k Views
  • theobliviousT Offline
    theoblivious
    As title says,
    amp shows its receiving power, but there is no sound coming out of the sub.
    I have a 120 watt amp connected to my sub (i know its rather small). Both are clarions (clarion can handle 750 peak). They have both worked before.
    THe problem started occuring a week ago with my old battery not being able to sustain my ac and sub woofer. (or so i think). So i installed a new battery and bought a capacitor (1.6 farad). I installed the new battery today and still i receive no sound from the amp.
    Footnotes:
    I dont have an aftermarket HU
    120 watt amp with sub
    -gets power but no sound
    I checked the fuse on the amp and its good, i also checked the fuse from the battery to amp, and its obviously good (or else i wouldnt be receiving power).
    are there any other fuses i need to check?
    BOOST....to be continued
      Do you have a multimeter?
        First, hook up a different speaker. It doesnt matter what kind of speaker or whether its even a subwoofer. Your just making sure the amp itself is putin out any sound. If it does, then it has to either be your subwoofer itself or a wire going to it. Either in the enclosure itself or to the enclosure.
          theoblivious
          i dont have a multimeter i have a light meter (not sure if thats what its called...the thing with the light in it and a ground.)
          • XJHEADX Offline
            XJHEADX Offline
            What turns on the amp?
              theoblivious
              When i press the power button on my stock head unit.
              • XJHEADX Offline
                XJHEADX Offline
                Try by-passing that by using the amps power feed into the remote on.
                  Is it plugged in?
                    theoblivious
                    im sorry im a real newb...are you saying disconnect the remote wire?
                      Trafik Jamz
                      Aside from what Wes/Bill have suggested:
                      have you messed with the fader on the deck? If so, make sure that there is signal going to whichever set of speaker outputs is providing signal to the deck.
                      Double check to make sure that somehow the speaker wire hasn't come loose on the sub as that would cause the no output possibility as well.
                      701.541.3484
                        Ya, what we said.
                        Like I said in my first post , process of elimination. all of which will take 10 minutes to test all.... MAX. Do it all in that order.
                        • XJHEADX Offline
                          XJHEADX Offline
                          Just re-read your orig. post. You state the amp is getting power. Is there a light on it that turns on when you turn on the H/U? If the light turns on when you turn on H/U then it is not the remote wire. The H/U sends 12 volts via the remote wire to tell the amp to turn on. If power is not being sent on that wire the amp won't turn on. That is why I said just jumper a wire from amp feed to the remote connection to see if it would work. If that is the case then the remote feed wire is the problem. Have you tried the other suggestions?
                            theoblivious
                            yes when i turn on the my HU, there is a blue light that turns on from the amp. Do i still need to jump the two wires?
                            I will get another speaker tomorrow from a friend and will test out if the sub is the problem.
                            If im understanding everything correctly:
                            1. If another speaker works, then its an issue with the sub
                            2. if it doesnt work, then its an issue with the amp. Is there any way to determine what is wrong with the amp exactly? Sorry if i am being redundant.
                            Thanks for all your help
                              Trafik Jamz
                              I believe you bought that amp from me, correct? If so, I can try and get it fixed (under warranty if it hasn't been over a year or so)
                              701.541.3484
                              • XJHEADX Offline
                                XJHEADX Offline
                                No it is working correctly
                                Sub or the wires feeding it
                                You don't know if you have a audio signal reaching the amp yet. Try the new speaker with wire first.
                                Chuck is there a easy way to see if a signal is getting to the amp without putting a new amp in?
                                  Take a known good source and hook it up to the amplifier.
                                  • BlueSRT0483B Offline
                                    BlueSRT0483
                                    Does your factory HU have RCA preouts? How is the amp knowing how to play the music? Is there a function that turns off your preouts, or whatever is used to to turn off the amp? I know on my deck, I can turn my subwoofer off, but I don't believe it turns off the amp itself.. Just stops sending the singal to power the subwoofers.
                                    Have you checked the wires on the inside of the speaker box, did any of them come loose?
                                    2004 Dodge SRT-4
                                    ...Formerly "A853"...
                                      Trafik Jamz
                                      No
                                      Turns on w/ ignition...receives signal through speaker level inputs or line output converter
                                      No....except maybe the fader being set wrong
                                      Not applicable
                                      Isn't that what 3 or 4 of us already suggested in some way shape or form? (though it is still good advice)
                                      701.541.3484
                                      • i_like_eggsI Offline
                                        i_like_eggs
                                          theoblivious
                                          thanks for all the help, ill give this a shot when i can find another speaker. As for the amp, i believe i bought it from you 2 summers ago :(.
