  4. New Stuff
New Stuff
461 Posts 56 Posters 70.8k Views
    Anyway, so parker can't make fun of me for having a "junkyard 4.8 motor"
    .030 over 6.0 - - 370ci
    Scat H beam rods
    Manley forged pistons
    Clevlite77 bearings
    LS2 crank
    Hellfire rings
    Ported LS6 oil pump
    Rollmaster double roller timing chain
    GM MLS 5 layer HG's
    ARP fasteners
    L92/LS3 heads
    Comp 918 valve springs
    Ti retainers
    SS intake valves
    Comp hardened pushrods
    GMPP valve covers (coils in car now)
    Custom Comp 224/230 .595/.605 114+2 LSA boost cam
    L76/LS3 intake
    PTM 90mm TB
    60lb injectors
    need a stall and some other stuff so i can stick the motor in
    shooting for 425 wheel on motor alone, could do better
    oh, and this intake setup sits 4" lower, so a 100% stock hood should be suffice........ so ridinrails needs new material now
    • dubbsyD Offline
      dubbsyD Offline
      no rotary no care...
      oh wait...
        You got ripped off. You didn't get a Vtec solenoid when you bought all that stuff. Hows Vtec going to hit if you dont have the solenoid. Pfft.
          I see you decided to run on 7 cylinders, interesting choice....
          What compression are you running??
            building my own, dual stage Vtec, better yet
            ha, i am impressed...... I noticed there was an injector gone when i loaded the pics... it was in the house still
            10.0 comp
            • SlowicaS Offline
              SlowicaS Offline
              Slowica
              sexy motor
              • no_slow_clapN Offline
                no_slow_clap
                looking good zac, what do you use to tune that?
                EVOLUTION VIII
                  dsmlink
                  • Afsil80A Offline
                    Afsil80A Offline
                    Afsil80
                    integra_gsr98;256278 wrote:
                    dsmlink
                    SAFC yields better AFR's.
                    -Peter
                    1991 240SX
                      no_slow_clap
                      dsmlink
                      really? i though he would have used mitsulogger.
                      EVOLUTION VIII
                        Nistune ftmfw.
                        Looks great Zac. When ya dropping it in?
                          did you drill the lifter trays at all??
                          ever figure out what those injectors are yet?
                          by the way, thats quite the awesome engine stand you got there, where did you get it?
                            shits still weak... forged rods? crank?...... weak
                            4 bolt main block 350 1 piece rear main
                            line bored and stroked to a 383 3.75 stroke
                            eagle 4340 forged rotaing assembly
                            6'' eagle forged H-beam rods
                            SRP 138093 forged pistons
                            Federal H series bearing
                            Perfect circle flie fit rings
                            Balnced and blueprinted
                            ARP Studs all around
                            10.8 compression
                            RHS Proaction aluminium heads
                            Started with 200cc runners
                            Full competition port job
                            Full Comp valvetrain
                            Comp Hyd roller lifters
                            Comp .080 hardened molly pushrods
                            Comp 152 promag rockers
                            SS valves
                            Comp dual valve springs
                            Ti retainers
                            Comp 314 cam .600 lift
                            Comp timing kit
                            Edelbrock Victor Jr. intake full port and polish
                            • z31Z Offline
                              z31Z Offline
                              z31
                              Hang a snail on it. :icon_bigsmurf:
                              • JN210J Offline
                                JN210J Offline
                                JN210
                                niiiiiice!!!!!!! that will be kickass
                                *1989 Nissan 300ZX Z31 *
                                > DelSlow;262050 wrote:
                                > I like the new JN210
                                  • SlowicaS Offline
                                    SlowicaS Offline
                                    Slowica
                                    Parker;256338 wrote:
                                    why isn't it summer and SLs yet
                                      yep, stole if from some bastard, haha
                                      huh? rods are forged and the stock nodular cranks have gone 1200whp+
                                      And i use HP tuners on a 2.5 bar custom SD OS
                                        yeah... they HAVE gone 1200whp.... but that means nothing... man up, buy a forged crank...
                                          it means it will have absolutely no problem at half that power, which i could never use anyway
