  4. got the pos running but
15 Posts 7 Posters 783 Views
  • My NOvaM Offline
    My NOvaM Offline
    My NOva
    hey got the nova running now finaly, but after i changed my intake gaskets got it running theres more oil deposting please some one help, 🆒 :mad:
    Hey Tina come get some hamm
    • G Offline
      G Offline
      GraveDigger
        • G Offline
          G Offline
          GraveDigger
          • NickBN Offline
            NickBN Offline
            NickB
            Shut the fuck up, you guys are ridiculous...maybe you should take your car to a shop?...might solve your problems...
            • FlowcusF Offline
              FlowcusF Offline
              Flowcus
              Where are the mods at? This is the 2nd thread Gravedigger has hijacked...
              FUCKING BAN GRAVEDIGGER!
              I ride random bitches.
                not my area to mod....
                  Done. Gravedigger go whore somewhere else. There are rules. ABIDE BY THEM!
                    Nova, did you use a distributor mounting gasket? Also are your valve covers aluminum? If they are, there could be a crack causing your leak.
                    • My NOvaM Offline
                      My NOvaM Offline
                      My NOva
                      thats a start thanx there wes they are aluminum 😄 duh didnt think about that but one thing my buddy and i noticed was some steam coming from one of the intake bolts 😕 i know everything got seated but why would that happen?
                      oh and yes i did use a gasket ill try for some pics
                        Take that bolt out and put some thread sealant on it and reinstall and torque it to spec. Then take some brakeclean to the whole area that the oil was going to. Get it totally clean and dry. Then start it up and let it run while watching it. The oil leak should be easy to spot. If that doesnt work, go to napa or other part store and get some engine oil leak tracer dye and pour the whole bottle in. Dont worry it's only a coulple of ounces. Then get a black light and hold it over the engine compartment while the engine is running. It WILL show up then. You dont need a special light for this. If you dont have a black light, just go to walmart and pick up a black light bulb and screw it into any houshold lamp. But beware you will find more leaks than you bargained for.
                        • My NOvaM Offline
                          My NOvaM Offline
                          My NOva
                          yeah when i put the bolts in i used thread sealer and as for napa i hate napa
                          i havent tryed the dye just yet i need to try to do it when its darker main thing i need is a job man power cant find me a job
                            Today I saw the problem, and its for sure coming out the bolt holes/threads I would talk to Automotive Specialties and see what they tell you to do. I would maybe sign up for the interstate drag way forum and ask on there they, know the v-8's well!!
                            Kevin
                            sls
                              Is it the intake bolts? If so, exactly which ones? You should have six per side. is it drivers side or passenger? is it front, middle or rear?
                              • My NOvaM Offline
                                My NOvaM Offline
                                My NOva
                                middle 1234 bolts that have to be torqued first
