  4. problems with a VR4
problems with a VR4
16 Posts 11 Posters 1.1k Views
  • Cura86C Offline
    Cura86C Offline
    Cura86
    DelSlow;257963 wrote:
    A 3000GT with transmission/clutch problems? Weird. You'd think it was a DSM...wait.
    Technically a 3000GT is not a DSM. All 3kgts and stealths were built in the Nagoya Mitsubishi Plant in Japan.
    As far as your problems go I would say its something in your tranny. Those getrags were horrible and they are expensive to fix.
    Let me know if you need anything, I have a few tranny parts laying around, but it sounds more like a clutch issue.
    www.RoadsideSalvage.com
    • ihaveaidsI Offline
      ihaveaidsI Offline
      ihaveaids
      Did the pedal go right to the floor? Try bleeding it maybe? Idk anything about these cars besides that the trans is pretty weak.
        see if your slave cylinder line has a hole in it. stock ones go bad around the couplers.
        the third gear synchros on my tranny are shot and ive been driving on it for two years. ive shoved it into gear at 7k and it didnt break. weird.
          How much you want for it?
          • D S ohMD Offline
            D S ohMD Offline
            D S ohM
            Bad slave maybe?
            I wanna go fast!
              D S ohM;257997 wrote:
              Bad slave maybe?
              Whip them when they misbehave.
              • D S ohMD Offline
                D S ohMD Offline
                D S ohM
                Hawt dayum! My thoughts exactly.
                I wanna go fast!
                  master and/or slave, then bleed...sounds like something rubber just gave way with all the cold weather and now there's no clutch pressure...
                  done and done.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Master, slave, hose, or something with your clutch itself. Look for leaking fluid up under your dash where the clutch pedal connects to the master cylinder and also around your slave cylinder on the transmission.
                    • killer69penguinK Offline
                      killer69penguin
                      yes i was told most likely the slave or a hose, and no there is no clutch pressure but the tranny itself is still very strong i had someone take a peak that knows a bit and that was everything he made out of it
                      1993 3000GT VR4
                        $3000 ill take it
                        • ExTREMEE Offline
                          ExTREMEE Offline
                          ExTREME
                          Bent clutch fork?
                            PSiedTSi;258405 wrote:
                            $3000 ill take it
                            x2. Id take advantage of that....
