  4. WRX Squeals in Reverse
25 Posts 12 Posters 2.1k Views
  • RexwagonR
    RexwagonR
    metal clips might be hitting. they could be dirty, have you tried cleaning them? spray some brake cleaner on them. there could be a little bit of rust on the pads.
    could be a rock jammed between the rotor and backing plate.
    you could also try slamming on your brakes a few times to see if it cleans them off.
    your pad could be sticking too. take them off and clean them.
    • ParkerP
      ParkerP
      wet brakes.... rust... nuff said
      BlueSRT0483;244555 wrote:
      Trafik Jamz;260984 wrote:
      You are right Parker.
      • ColinC
        ColinC
        Colin
        the in reverse part is what makes me say e-brake.
        • GarageAlchemistG
          GarageAlchemistG
          GarageAlchemist
          unless you are planning on driving around backwards....
          97 GTi, 03 KJ
          • STi ScottS
            STi ScottS
            STi Scott
            KA-T_240;259957 wrote:
            It could be your e-brake. Did this happen before you got hit?
            No it didn't start when I got hit, it just started like a week ago.
            Sounds like its a brake issue for sure. I'll take a look at them soon here. Thanks for the tips!
            '05 Subaru STi
            • HiImBrianH
              HiImBrianH
              HiImBrian
              I still think your motor is shot and you should just give it to me. Maybe it's the sway bars. In that case you should give em to me as well 😉
              I powdercoat. If it can fit in my oven, I can do it cheap.
              • treimcheT
                treimcheT
                Isn't this pretty common on Subarus?
                • K
                  K
                  Is what common?
                  • ParkerP
                    ParkerP
                    KA-T_240;260595 wrote:
                    Is what common?
                    what the fuck were we just talking about?
                    • K
                      K
                      Your tranny luck?
                      • ParkerP
                        ParkerP
                        wow... welcome to 2004....
                        • treimcheT
                          treimcheT
                          The brakes squealing in reverse. I think Nick's STi had that same thing.
                          • RexwagonR
                            RexwagonR
                            yep
                            • STi ScottS
                              STi ScottS
                              STi Scott
                              I still haven't gotten around to actually looking into it.
                              What was the problem with his?
                              Rexwagon;261443 wrote:
                              yep
                              If it is a common problem is there a common solution?
                              '05 Subaru STi
                              • MisterCMKM
                                MisterCMKM
                                Is it more of a stuck pig type squeal or a teenage girl squeal?
                                thrash;315544 wrote:
                                Ford is back :)
                                • ParkerP
                                  ParkerP
                                  does it happen all the time? or after the car sits for awhile(a day or more)?..
                                  • STi ScottS
                                    STi ScottS
                                    STi Scott
                                    It happens all the time.
                                    '05 Subaru STi
