Anybody donate plasma?
ive heard you cant donate if you have a tattoo... any truth in this?
alrite cuz im down to donate... its been 7 months since i got mine
DelSlow;260616 wrote:
You cant sleep because if you do you will loose blood pressure in the arm they are taking it from....so....its actually REALLY stupid to fall sleep while doing that. In fact you are fucking retarded if you do.yes, because every time you fall asleep your body just shuts of all blood supply to your limbs.
:roll:
dubbsy;260650 wrote:
yes, because every time you fall asleep your body just shuts of all blood supply to your limbs.:roll:
Hmmm i take it you have never donated plasma...
Because yes, if you don't pump your hand/make a fist every 2 mins or so the pressure on you arm will drop so that the machine will not work properly and will turn off, and can cause air embolism.
But that doesn't mean anything, listen to dubbsy, he knows everything and is neat. -
I used to do it all the time at Biolife, about 4 years worth. I was permanently deferred for testing out of whack for some liver enzyme, I had never tested bad for anything ever not even elevated levels of any of the stuff they test for. So I asked if it could have been the test? She said yes, So I asked if I could take it again, She said NO. Gay!! My personal best was 38 minutes in and out, and they took 800mL from my big ass.
PS where is the one in Moorhead, maybe I'll go over there and start doing it again.
DelSlow;260651 wrote:
Hmmm i take it you have never donated plasma...Because yes, if you don't pump your hand/make a fist every 2 mins or so the pressure on you arm will drop so that the machine will not work properly and will turn off, and can cause air embolism.
Oh I've donated plasma enough...
Fact is - you said you lose blood pressure in your arm when you fall asleep. If you lost blood pressure in your arm every time you fell asleep you'd have gangrene and wouldn't have a limb to donate blood from. The fact is - falling asleep simply removes you from the task of artificially inflating the arterial pressure in the arm that is giving blood - artificial pressure that - yes - is necessary to push evacuate blood from the body and into the machine. Any drop (but never loss - unless the limb is removed or you've died) in blood pressure - which will be minimal at best - from falling asleep is purely coincidental and likely due to the decrease in stress. -
And yes, I was donating quite a bit for a while there. Got bored and lacked ambition to go every day (and got to the point I hated being tied to a machine for an hour and a half) so I haven't been back in nearly a year.
I'd just say bring a laptop and watch your favorite TV show. Easiest way to pass time with one hand free.
Fact is - you said you lose blood pressure in your arm when you fall asleep. If you lost blood pressure in your arm every time you fell asleep you'd have gangrene and wouldn't have a limb to donate blood from. The fact is - falling asleep simply removes you from the task of artificially inflating the arterial pressure in the arm that is giving blood - artificial pressure that - yes - is necessary to push evacuate blood from the body and into the machine. Any drop (but never loss - unless the limb is removed or you've died) in blood pressure - which will be minimal at best - from falling asleep is purely coincidental and likely due to the decrease in stress.It is also difficult to tell the difference between somebody that is sleeping by choice and somebody that has passed out for whatever reason.
