  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 52.0k Views
  • 63vette6 Offline
    63vette6 Offline
    63vette
    Wow, you did get a lot done!
    • XJHEADX Offline
      XJHEADX Offline
      zbrown;260625 wrote:
      how did everything look in the motor?? better or worse than you expected??
      Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.
      • 63vette6 Offline
        63vette6 Offline
        63vette
        valve timing was off a hair.
        • 63vette6 Offline
          63vette6 Offline
          63vette
          no avatar wtf???
          ahhhhhh thats better.. 🙂
            XJHEAD;260630 wrote:
            Only thing I thought was odd was the intake runners in the head had some tar-like sludge on the bottom of them. I think it may be too rich at part throttle cruising. It always felt like it wanted to stumble when cruising around. Besides that everything else looks good. I thought it would be a little cleaner on the valves. But not bad for what it has been through. 150+ dyno pulls, 40 or so passes last year and who knows how miles Andy put on it while it was down in SD. I always wondered why the back seat stunk.legacy image
            E98 will clean those valves right up. Mine looked cleaner after running all season than they did when I put them in.
            • z31Z Offline
              z31Z Offline
              z31
              Here is the before picture. :icon_bigsmurf:
              • XJHEADX Offline
                XJHEADX Offline
                Took about 40+ lbs out last night and today. Everything else is pretty much stripped already.
                • XJHEADX Offline
                  XJHEADX Offline
                  Just weighed the car;
                  No engine
                  No Tranny
                  No Fuel
                  No turbo/exhaust
                  2025 lbs. should be right around 3100 lbs. when back together.
                    No engine
                    No Tranny
                    No Fuel
                    No turbo/exhaust
                    So 3350 lb with driver?
                    • XJHEADX Offline
                      XJHEADX Offline
                      Watcha trying to say???
                      3100 with driver
                      :ford: rulz this year................................
                      • 63vette6 Offline
                        63vette6 Offline
                        63vette
                        How much does your new bruno/lenco weigh? 🙂
                        • XJHEADX Offline
                          XJHEADX Offline
                          So yesterday I was putting in the mock-up motor into the car. Put the tranny back in too and saw this.
                          The K-member cross bar sits higher than my Cobra one. Leaves the pan just exposed. If I pull a DaveH it won't be pretty.
                          I pulled it out last night and today pulled the one out of the Cobra and put it in. Looks much better. Motor isn't all the way dropped in on the drivers side that is why it is a little crooked.
                          • 63vette6 Offline
                            63vette6 Offline
                            63vette
                            Whats the measurement of your crank c/l at ride height?
                            • z31Z Offline
                              z31Z Offline
                              z31
                              Good idea. :icon_bigsmurf:
                              • XJHEADX Offline
                                XJHEADX Offline
                                I have it written down somewhere for the cobra. I won't be able to get you a number until I get everything installed and set my suspension up. My best guess would be somewhere around 17-18".
                                • 63vette6 Offline
                                  63vette6 Offline
                                  63vette
                                  Being this is a lot lighter car you may want to lower that a couple inches if possible, or get really beefy wheelie bars.
                                  You are getting it done though thats for sure. That thing ought to be running by next week.
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    The only way I could lower is if I relocate the steering rack.. It is possible, just some welding. I may ditch my motor mounts and go solids or motor plates. I was stretching the steal apart on my Energy Suspension ones.
                                    EDIT; wheelie bars are for sissies
                                    I have the top left ones in the pict. The outer shell was being pulled apart
                                    • 63vette6 Offline
                                      63vette6 Offline
                                      63vette
                                      Ohhh here we go with the wheelie bar - sissy argument again.
                                      Wheelie bars are a safety device to me. Its got nothing to do with balls. On a 9 second car...errr no. On your car....yes. Get it all dialed in on our greasy little track then take it somewhere that hooks, when everything forward of the firewall is destroyed I will buy you a beer and get to say I told you so. 🙂
                                      Im just sayin....
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        One of the changes I had planned on making was getting rid of the 1-5/8" exhaust tube and change out to 1-3/4". It should help it breath a little better. I started on one side today/tonight.
                                        I can actually access the plugs so far.
                                          good job bill! you just gonna run the downpipes out the side this time? would sure make stuff alot easier. BTW, you still running on-center housings on those turbos? If you are you should really find a pair of tang housings and you would probably pick up a good 150hp, on center housings are FTL big time
