  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
  • XJHEADX Offline
    XJHEADX Offline
    63vette;261984 wrote:
    Whats the measurement of your crank c/l at ride height?
    I have it written down somewhere for the cobra. I won't be able to get you a number until I get everything installed and set my suspension up. My best guess would be somewhere around 17-18".
    • 63vette6 Offline
      63vette6 Offline
      63vette
      Being this is a lot lighter car you may want to lower that a couple inches if possible, or get really beefy wheelie bars.
      You are getting it done though thats for sure. That thing ought to be running by next week.
      • XJHEADX Offline
        XJHEADX Offline
        The only way I could lower is if I relocate the steering rack.. It is possible, just some welding. I may ditch my motor mounts and go solids or motor plates. I was stretching the steal apart on my Energy Suspension ones.
        EDIT; wheelie bars are for sissies
        I have the top left ones in the pict. The outer shell was being pulled apart
        • 63vette6 Offline
          63vette6 Offline
          63vette
          Ohhh here we go with the wheelie bar - sissy argument again.
          Wheelie bars are a safety device to me. Its got nothing to do with balls. On a 9 second car...errr no. On your car....yes. Get it all dialed in on our greasy little track then take it somewhere that hooks, when everything forward of the firewall is destroyed I will buy you a beer and get to say I told you so. 🙂
          Im just sayin....
          • XJHEADX Offline
            XJHEADX Offline
            One of the changes I had planned on making was getting rid of the 1-5/8" exhaust tube and change out to 1-3/4". It should help it breath a little better. I started on one side today/tonight.
            I can actually access the plugs so far.
              good job bill! you just gonna run the downpipes out the side this time? would sure make stuff alot easier. BTW, you still running on-center housings on those turbos? If you are you should really find a pair of tang housings and you would probably pick up a good 150hp, on center housings are FTL big time
              • XJHEADX Offline
                XJHEADX Offline
                Thanx, going slow but I am making progress. I would like to go out the fenders but it is so obnoxious. I haven't decided. I went to tangs when I swapped to the 78's. I am hoping for some improvements up high with the larger tubing. Pretty much changed everything in the fall of 07' never saw huge gains. Everything that we did change made improvements though, so wasn't wasted time. The only thing that wasn't changed back then was heads and exhaust manifolds.
                  Have to have exhaust running out under the car if you want to play in RS or KS.
                  • XJHEADX Offline
                    XJHEADX Offline
                    I can always make both I guess.
                      XJHEAD;262251 wrote:
                      guessing mild steel?
                      looks good
                      • XJHEADX Offline
                        XJHEADX Offline
                        looks good
                        Yes, mild steel. I'm a cheap bastard. Don't have a tig either.. It was a kit I bought over 2 years ago. Figured a good time to use it. If I ever get the car done I think I'll make a trip to Dynotune to see if it made a difference or not. The only other change that I may do is have the intake cleaned up.
                          oh yeah it will definately make more power. most people say over 950 or so whp the 1.75 tubing will start showing noticable gains. Im glad you got rid of those on center POS's too, just dont like them! For exhaust you could do the turbines toward the fenders and run the exhaust down between the strut and the frame easy enough, and out through the fenders in front of the doors. That would still get you past the firewall i think, and would look/sound badass.
                          • 63vette6 Offline
                            63vette6 Offline
                            63vette
                            You have a lot of stupid advice. How fast is your POS Mr. Helper?
                              are you serious asshole? you have no idea who i am and i do have very good advice, ive put so many hours into reasearching turbo stuff its rediculous. Not like i have daily driven a 700hp turbo car for 2 years, keep your personal assaults to yourself
                              I would like to add that i notice you have decent sized travel limiters on there, making running the pipes through that area a little difficult. I see it done alot on SN95s though so there may still be room, would keep alot of heat out of your engine bay
                              • 63vette6 Offline
                                63vette6 Offline
                                63vette
                                No, I dont know who you are, and dont really care. What events have you won? Are you John Force? Bull Lutz? Bob Glidden? Why would I know you? Should I buy a vowel?
                                My pumpgas pos daily driver is over 700 with no juice or boost. Its not a personal assault, What do you know about 7-8 second cars? Nothing?
                                2 years.... I have shit stains in my driving suit older than that. Bwahahahaha
                                  well thanks for coming off as a complete piece of shit, glad a grown ass man can be such a douchebag on a public forum. Ill put you on my ignore list and i suggest you do the same
                                    My guess is either the little blue pills are losing their affect for "Mr. 7 Second" or he is truly a 7 second kind of guy.... and he is just lashing out at people tonight in frustration
                                    Just a guess though
                                      Glad all of the fast guys like Dave, Matt, Bill, ect..... are not all arrogant old men like yourself
                                      That is why i respect them.... and not you
                                      Big deal though.... you don't care who i am either so it's all good
                                      • 63vette6 Offline
                                        63vette6 Offline
                                        63vette
                                        Did I call you a piece of shit or a douchebag? I assumed you were a grown man, my mistake boy. Have a nice day.
                                        • 63vette6 Offline
                                          63vette6 Offline
                                          63vette
                                          Please point out where I was arrogant.
                                          Haha are you calling Bill, Dave and Matt old?
                                          I am sorry if it hurts your feelings but I dont give a shit if you respect me or not. :icon_salut:
