  4. Disabling Auto Headlights
71 Posts 18 Posters 9.6k Views
    Joel;262330 wrote:
    Are you mentally retarded? It doesnt matter what kind of bulbs are in your housings... They are all going to reflect the same direction off your reflectors... Unless you have aftermarket projector style housings.
    Not to be a dick but that is 100% wrong
    The characteristics and dimensions of the arcs are completely different..... and will not function properly in a housing not designed specifically for each individual bulb
    good bookmark
    http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
    and ill add to the thread for Wes
    http://reviews.ebay.com/HID-XENON-CONVERSION-KIT-TROUBLE-SHOOTING_W0QQugidZ10000000001215090
      DRL's run the bulbs at about 60% power... most of the time on high beams... so my guess is thats why he wants to disable them...
      • dubbsyD Offline
        dubbsyD Offline
        nope.
        Not since 2000 has GM done this on their trucks. In 2000.5 they went to a designated DRL. As far as I knew they've continued this design.
          dubbsy;262379 wrote:
          nope.
          ok.... im speaking for dodge and subarus... i could give a fuck less about chevys....
            SPANISH-RICE;262349 wrote:
            Dont disable the dtr lights. It wont ruin the headlights it will just use them all the time. I guess knock more life off them? But if your goal is ultimatly "more light" then why not always have "more light". Since really its just for the ricer image
            besides, dtrl's are for safety. their good to have
            I never said anything about disabling day time running lights. Where the fuck did you get this? I said I want my Auto headlights turned off, nothing else. Also, Why the hell would I need more light during the day, you're playing devils advocate and failing miserably. I'll take my chances in turning off my DRLs if thats what is involved in getting rid of the auro headlights. I usually run my headlights during the day anyways. I am not concerned about my headlight being on during the day, but the fact that they turn on in the accessory position. Then, while cranking, it cuts power as the HID is trying to turn on, then Powers them up again. I asked a pretty reputable source about this who has had to warranty a bunch because of this situation.
              What type of bulbs does your truck have? I will look for a set of good high-output bulbs(not SilverStar junk). Put them in your low and high beams and it will be much more light then stock.
              If you want to try and do a OEM HID retrofit. I am more then willing to help. I have wanted to try and do this.
              Why not just not use the auto headlights? Pretty sure my Dad's 05 Colorado has the option for auto and manual.
                9006 low, 9005 high, not sure whats in the fogs.
                Read my post above you for answer to auto headlights question. You can turn the auto headlights off after you start the truck. which I don't want to do every time I get in the vehicle.
                  The auto lights is not what kills HIDs. It is that they get turned on and off multiple times. Regular bulbs have the same problems.
                  A Selective-Yellow bulb in the fog lights really helps light up the road when its snowy outside.
                  http://forums.nasioc.com/forums/showthread.php?t=954736
                  I have Phillips VersionPlus +30 bulbs in my WRX.
                    Trafik Jamz
                    This went horribly off topic, but the points being made are good. For the safety of everyone else on the road, please don't put HID's in non-HID housings.
                    701.541.3484
                      WTF do u think I just said? The truck turns the lights on and off twice as many times with the auto lights...
                        Trafik Jamz
                        http://fargostreet.com/forums/showthread.php?t=1919&highlight=cutoff
                        701.541.3484
                          lawl.
                            DelSlow;262432 wrote:
                            lawl.
                            You do realise that did not disprove what I said, correct? I said the bulbs will reflect the same way. Halogens do not have a cut off. I do not expect HIDs in my stock housings to have a sharp cut off. it will give me more light, and I could give 2 shits less about the person driving in front of me.
                              wow that is very douchbag-ish of you. If im ever behind you i will be sure to put all of my 280watts of xenon right into your mirrors. And dont put hids in those fucking stock housings, they are terrible and your liable to cause an accident. In fact, if someone hits you at night and they say that your lights were not regulation you are at fault, and it can be proven in court quite easily
                                and to add, assuming your colorado has very similar wiring to my envoy, the auto headlights are part of the BCM and can only be disabled by splicing a small control box into the harness, if you go on a colorado forum it will be easy to find
                                  I agree, but im pretty sure in the century code it just says two forward facing bulbs XX centimeters off the ground yada yada. Nothing about being 'regulation' and color really.
                                    Yeah I'm sure you and Chuck's first thing you think about when modding your cars are other peoples safety... I'm sure neither of you have ever street raced before,
                                    AFAIK, it IS Illegal to put High Intensity Discharge headlights into a vehicle which is not factory equiped with them. Like I said, I'll take the chance in getting pulled over, or being liable for an accident at night if someone claims it had to do with my headlights...
                                      why would someone hit you at night if you have HID's in your non HID housing. They should be able to see you then. If anything they will hit the ditch or something.
                                        ungodly glare would come to mind as why you could get hit. pretty hard to avoid someone if you dont know where they are in a 20ft wide orb of piercing light
                                          blah blah blah.... is any of you see someone with HID's... none of you would say SHIT about the housing they are in...
                                          and again.... blah blah blah...
