  4. Disabling Auto Headlights
71 Posts 18 Posters 9.9k Views
    What type of bulbs does your truck have? I will look for a set of good high-output bulbs(not SilverStar junk). Put them in your low and high beams and it will be much more light then stock.
    If you want to try and do a OEM HID retrofit. I am more then willing to help. I have wanted to try and do this.
    Why not just not use the auto headlights? Pretty sure my Dad's 05 Colorado has the option for auto and manual.
      9006 low, 9005 high, not sure whats in the fogs.
      Read my post above you for answer to auto headlights question. You can turn the auto headlights off after you start the truck. which I don't want to do every time I get in the vehicle.
        The auto lights is not what kills HIDs. It is that they get turned on and off multiple times. Regular bulbs have the same problems.
        A Selective-Yellow bulb in the fog lights really helps light up the road when its snowy outside.
        http://forums.nasioc.com/forums/showthread.php?t=954736
        I have Phillips VersionPlus +30 bulbs in my WRX.
          Trafik Jamz
          This went horribly off topic, but the points being made are good. For the safety of everyone else on the road, please don't put HID's in non-HID housings.
          701.541.3484
            WTF do u think I just said? The truck turns the lights on and off twice as many times with the auto lights...
              Trafik Jamz
              http://fargostreet.com/forums/showthread.php?t=1919&highlight=cutoff
              701.541.3484
                Joel;262330 wrote:
                Are you mentally retarded? It doesnt matter what kind of bulbs are in your housings... They are all going to reflect the same direction off your reflectors... Unless you have aftermarket projector style housings.
                lawl.
                  DelSlow;262432 wrote:
                  lawl.
                  You do realise that did not disprove what I said, correct? I said the bulbs will reflect the same way. Halogens do not have a cut off. I do not expect HIDs in my stock housings to have a sharp cut off. it will give me more light, and I could give 2 shits less about the person driving in front of me.
                    wow that is very douchbag-ish of you. If im ever behind you i will be sure to put all of my 280watts of xenon right into your mirrors. And dont put hids in those fucking stock housings, they are terrible and your liable to cause an accident. In fact, if someone hits you at night and they say that your lights were not regulation you are at fault, and it can be proven in court quite easily
                      and to add, assuming your colorado has very similar wiring to my envoy, the auto headlights are part of the BCM and can only be disabled by splicing a small control box into the harness, if you go on a colorado forum it will be easy to find
                        I agree, but im pretty sure in the century code it just says two forward facing bulbs XX centimeters off the ground yada yada. Nothing about being 'regulation' and color really.
                          Yeah I'm sure you and Chuck's first thing you think about when modding your cars are other peoples safety... I'm sure neither of you have ever street raced before,
                          AFAIK, it IS Illegal to put High Intensity Discharge headlights into a vehicle which is not factory equiped with them. Like I said, I'll take the chance in getting pulled over, or being liable for an accident at night if someone claims it had to do with my headlights...
                            why would someone hit you at night if you have HID's in your non HID housing. They should be able to see you then. If anything they will hit the ditch or something.
                              ungodly glare would come to mind as why you could get hit. pretty hard to avoid someone if you dont know where they are in a 20ft wide orb of piercing light
                                blah blah blah.... is any of you see someone with HID's... none of you would say SHIT about the housing they are in...
                                and again.... blah blah blah...
                                • GarageAlchemistG Offline
                                  GarageAlchemist
                                  Gary, if you are certain of this argument that Joel will be liable in the case of a head on collision becaue of his improperly equipped headlights, i will gladly ram his vehicle with my jeep.
                                  97 GTi, 03 KJ
                                    lolz!!
                                      I say shit to people with hids's and non proper housings all the time. It looks like complete ass and does nothing for being able to see better at night. It does how ever make the car obnoxious and unsafe. But as long as you get the fancy blue light, right? Thats 3/4 the reason why i stopped cruising, slow paced and constantly getting fucking shined with crap hid setups
                                      some cars will get more light on the road but at the expense of other drivers saftey. If you cant be standing outside your vehicle with your headlights on and look down at them with out hurting your eyes you fucked up.
                                      This goes for about 95% of people with those scat ass mks hid's they buy for 100 dollars and put in every fucking light hole they can find.
                                        joel;262447 wrote:
                                        you do realise that did not disprove what i said, correct? I said the bulbs will reflect the same way. Halogens do not have a cut off. I do not expect hids in my stock housings to have a sharp cut off. It will give me more light, and i could give 2 shits less about the person driving in front of me.
                                        you couldnt be more wrong. Have you done any research on this at all? Reflector style housings are designed to work with a certain light output. If you flood the housing with light its going to reflect in every direction instead of the one its meant to.
                                          Don't you have HIDs?? Projectors housings are not the same as HID housings...
