  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 51.0k Views
  • XJHEADX Offline
    XJHEADX Offline
    Anyone see a problem with the placement like this???
      could you have bearing issues like that possibly?
      • XJHEADX Offline
        XJHEADX Offline
        Never thought of that. The drain will still be on the bottom.
        Here are some close up welds. These are about as good as I get. Give me some 1/4"+ plate and a stick welder.
          Here are some close up welds. These are about as good as I get. Give some 1/4" plate and a stick welder.
          Those pics are mighty small but thats damn good for a stick welder. Looks like you might have a little bit of undercut on the top.
            Bill:
            Turbos should be ok to ~30 degrees of tilt. I'd imagine you won't have much of an issue at that angle.
            • XJHEADX Offline
              XJHEADX Offline
              I was chatting with the owner of this car last night. He had the same concept in a 57' and built this vehicle. He said he has no problems whatsoever. His are mounted 30* , mine wil be about 20*.
                I definitely like the way you have them oriented in there though.... looks hot
                • XJHEADX Offline
                  XJHEADX Offline
                  I thought it looked pretty good too. I got one side all welded up. Still need to add the w/g and start the other side. I'll have to move the inlet on the radiator now.
                  • ChristianC Offline
                    ChristianC Offline
                    Christian
                    Grr;262468 wrote:
                    Not like i have daily driven a 700hp turbo car for 2 years, keep your personal assaults to yourself
                    Which car do you have that has 700 hp? I just can't recall it at this time.:icon_scratch:
                    Playtime Performance
                    06 F-150 Lariat
                      serious? my gn made well into the 600s on pump gas all the time. And using simple math and dragstrip calculators put it in the 700hp area, and i never even turned it up at the strip. Now my T/A will make quite a bit more than 700hp, hopefully it will hook
                        ChristianC Offline
                        Christian
                        Oh I see. Have any dyno sheets on the GN. Why wouldn't you turn it up at the strip? I'm just asking isn't that the point of going out there, to see what it can run?
                        06 F-150 Lariat
                          everytime i went to the strip i was just out for a cruise and didnt want to break it. In fact ususally i didnt even have my scanner with and i just made some big change. I upped it to about 12psi in brainerd once but it was so damn hot out i didnt even want to run it, did 11.7@128 leaving off idle on my 1700 stall converter, 2.3 60'. When i ran 11.4@119 in sabin i was at 7-8psi and there was a 35mph headwind, 1.7x 60', it sucked that day
                              ChristianC Offline
                              Christian
                              Bring the T.A prepared this year and let's see what it can do. I'm interested what a 700 hp car can do. Your talking flywheel hp right? Not trying to be a dick just dosen't add up to me and I'm not a rookie at this shit.
                              06 F-150 Lariat
                                fallguy;262538 wrote:
                                The funny thing is that if they met each other at the track they prolly would get along famously. 🙂
                                x eleventybillion...
                                63vette is a good guy...
                                for having alot of grey hair..... :drunken_smilie:
                                  you.... are a badass....
                                    ChristianC Offline
                                    Christian
                                    You are a stud Parker.
                                    06 F-150 Lariat
                                      you bet, i plan on coming out this year a couple times, being its a stick and i dont wanna destroy the trans i dont expect it to be terribly fast. but all i have to do is idle down the track and get a timeslip to be faster than parker, so thats a plus!
                                        ChristianC Offline
                                        Christian
                                        Why even go then. Sounds like a waste of time to me. Let it rip and break some shit if you have to. Weed out the weak parts, come back stronger next time.
                                        06 F-150 Lariat
                                          haha.... i was just checking your sarcsim radar... you have passed....
                                          oh, and Gary... power parking FTW...
