  4. tech question
tech question
38 Posts 19 Posters 2.2k Views
    I believe this was the same turbo it had when kevin gave me a ride once...... def was impressed with the response
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      bowww down to da evo gooru ^^^^
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      > BlackEJ8;233529 wrote:
        aliengotpsi
        no_slow_clap;264772 wrote:
        a 2.3L stroker, some nuts, and a good harness.
        ok now seriously lol, look at the whiteline bumpsteer correction kit, and the front roll center kit. evo's push, and those help a lot. along with what faber said, a GOOD alignment.
        solid diff mount bushing wouldnt be a bad idea either, and some better front and rear sway bars if you dont already have them.
        Are you going to tune the car on this year?
        and what cams are you going to use?
        I have been looking at the bumpsteer kit and other stuff like that.. I already have aftermarket adjustable sway bars. Yes The car will get tuned in a few weeks at DB more than likly. I run HKS 264's for cams. The turbo spools just fine and dont think Going to a smaller turbo would help unless I was doing autocross.
        I was thinking about getting a aftermarket intake manifold but the buscher ported one makes more power than most! so for $140.00 Its a good deal.
        Kevin Smith
        Straightlinedetailing.com
          i couldnt begin to give you advice on what parts to consider, but i want to know when and where so i can watch you beat the shit out of that thing
          • no_slow_clapN Offline
            no_slow_clap
            an aftermarket intake mani wont help your midrange..i dont think.
            plus i hate buschur, so i wouldnt buy it.
            IMO, you should get some 280's. What fuel are you tuning on? race gas, pump, e85?
            EVOLUTION VIII
              Why's this?
                shift knob, first and foremost.
                • gsrEKG Offline
                  gsrEKG Offline
                  gsrEK
                  that is the best and most used first piece
                  A s2k
                    Cobra lights? For max boost?
                      DelSlow;264795 wrote:
                      Why's this?
                      please tell me this is a joke?
                        I would like to hear his explanation.
                          thrash
                          I don't know you or your car so i may come off sounding like more of a dumbass than usual, but if you haven't done road course work before, with that much go-fast stuff you'll want very good brake pads, fresh excellent brake fluid, and a harness. I've been happy with porterfield R4 full-race compounds and ATE Superblue/Type200 fluid. I don't know what race-compound pads are availabe in your caliper but im sure somebody does.
                          On most street cars the #1 thing you want is adjustable front camber when doing road-course work. Mostly this will help save your expensive tires on a big heavy car. Bring a white marker to the track with you and use it to get an idea of how much tire rollover you're getting at all 4 corners. Also a very accurate tire pressure gauge, a notebook, and keep careful records of what pressure seemed to feel good and manage tire-rollover and tire wear appropriately.
                          If you are looking to spend money on toys, the #1 thing you'll do to go faster around the track is an in-car data logger. You want to know position via GPS, RPM, TPS, g-circle, and speed. You can get into one of these for under $1k, which I am going to guess is small change compared to the rest of the work on that car.
                          If you're an accomplished road racer this is all dumb stuff you already know, and I apologize for wasting your time. If not, the biggest gains are made by making the driver faster, not the car.
                            aliengotpsi
                            Ive done my research on the manifolds and nothin beats the stock one ported up to 8,000rpms The car with make plenty of power.. Id say around a 10 sec 1/4 pass.
                            I thought about 280s but would need springs and retainers also for this summer i'll stay with 264's. More than likly going to go with a double pump and E85 1000cc-1200cc injectors (NOT PTE) I also have Meth Injection..
                            I do have harness belts and the stock seat is fine for racing ..
                            Kevin Smith
                              aliengotpsi
                              Maybe I can talk tufte in to making a brake cooling duct for my car also...
                              Kevin Smith
                                you'll probably want to upgrade brakes then also, the stock brembo's will get weak fast.
                                  Kevin we have stop-tech stage 2 brakes in stock at the shop for a steal if you want to do better brakes. stop in and talk to shane or jason on them.
                                  here is info on it
                                  http://www.stoptech.com/products/stage1_2_upgrades.shtml
                                    I saw you driving a while ago! Its good to see that thing back on the road!
                                      no_slow_clap
                                      Why's this?
                                      My explination is terrible, because im basing of my own expierence.
                                      anyone remember my consistant 14 sec passes in my civic (yes, slow)
                                      -bald...well shredded street tires, an exploded driver side motor mount, blown struts all around, and full interior.
                                      with the skunk2 intake mani on, it droped to consistant 15 sec passes. With a higher trap speed, and slower 1/8 mile. this was with street radials, new omnipower coilovers, new motor mounts with inserts from kyle, and a few other things.
                                      Thats my explination. I dont like them, they are sweet noise makers....thats about it.
                                      Kevin, you dont need upgraded valve train unless you plan to you RPM's over the stock rev limiter. There are plenty of people that have proved that.
                                      Not to mention, the kelford 272, and the gsc s2 out perform most 280 cams besides custom grinds.
                                      Also, i dont think you will need a double pumper with your setup.
                                      http://forums.evolutionm.net/drag-racing/383601-batmobile-goes-10-67-23psi.html
                                      this is a friend of mine. Single walbro 255, although on a 2.3. 1000cc injectors, on a race head, with a pump gas tune (the tune is arguable).
                                      but if you need a double pumper let me know, i can get you one for CHEEAAP.
                                      EVOLUTION VIII
                                        ^He needs the double pump for the additional fuel of E85!
                                        • ColinC Offline
                                          ColinC Offline
                                          Colin
                                          Kevin: I agree with thrash.
                                          You are the weak spot in this setup. No insult intended, I will also be in this position this summer with a lot less power though lol.
                                          You have built a car that surpasses you skills as a driver . Better parts and setups might make you car perform better, shave seconds, keep you under control, but they will only be making up for what you lack.
                                          Go to BIR, sign up for whatever classes you think will help you. Talk to Shane about "race" driving. He's probably the best driver you can easily approach in town. I would imagine he will have some good ideas for you.
                                          Thrashes ideas are good, but i would think you might want to put some research time into why and how to apply his methods. Except for seat time. Thats easy: you see, you put your butt. . . . . . . into the drivers seat.
                                          PS: I know a guy who would always be up to caravan all summer long/split hotels or whatever for brainerd trips. I'll get him in touch with you if you'd like.
