  4. Requested picts of our other crx
7 Posts 5 Posters 894 Views
  • E Offline
    E Offline
    excessive
    These picts are from last year... not much will change except for turbo sizing and switching from accel dfi to a aem ems.
    Specs:
    84.5mm ls/vtec
    golden eagle sleeved
    sc61 turbo (soon to be replaced)
    1mm larger valves stock ports
    1000cc injectors
    manifold, stainless piping and other misc built by excessive
    What else would you like to know about it?
      what kinda numbers did that produce?
      • E Offline
        E Offline
        excessive
        495whp on 21psi
        good axles were out of the budget last year so we stayed with a conservative setup... car could have been run on pump gas at that boost level. I think timing was only like 19 degrees at peak torque.
          Wow just wow. That is excessive.
            didn't you run 11s spining the tires all the way down the track up here with that car?
              is this mr keyman?
                it is indeed mr hogue
