  4. s2000 turbo
s2000 turbo
37 Posts 19 Posters 4.5k Views
  • E Offline
    E Offline
    excessive
    Picts are of a s2000 we turboed... 307whp on a stock motor tuned with a Aem ems
    By the way im headed to aem for the advanced training feb 2nd.legacy image
      thats nice...i think you were doing that or talkin about that when i was down there last
        Very cool.
          that's a nice car, what size turbo are you running on that?
          • E Offline
            E Offline
            excessive
            We put a t3/67 on it...
              how long till you have numbers of it with the turbo? if possible could you post a video of it when done too!!
              • E Offline
                E Offline
                excessive
                its been done for a bit... 317whp on 7 psi.... remember this is on a stock motor so far
                  wow that is really pimp. pm sent
                    Did you make that manifold too?
                    Brian
                      just my opion, but i think turbocharging an s2000 isn't a good idea... unless the intent is to use it as a drag car. if i were to own an s2000, i'd probably consider a sc or just good i/h/e and raise the compression to 12:1. on another hand... it's all about the driving habits. if there won't be excessive handling needed, then the turbo would be my choice
                        Joey, who's the bald guy installing that front mount :-p.
                          Dude, once again...
                          BOOST IS FUCKING BOOST.
                          Don't matter if it's red, black, blue, or green. Vortech, Garret, Paxton, whatever, positive manifold pressure, is positive manifold pressure.
                          And adding a turbo kit and gaining 100+ whp, compared to pulling the motor, putting in new pistons, intake, header, and exhaust, for 12+ whp isn't really worth it.
                          • 9 Offline
                            9 Offline
                            92TSIpos
                            integra_gsr98 wrote:
                            Dude, once again...
                            I was going to say 9 lbs from a sc should be the same as 9 lbs from a turbo.
                            (correct me if i am wrong)
                              you are correct sir
                                Well, sortof. The volume of air being moved @ 9 psi will vary the amount of hp being generated. For instance an s2k with a t25 @ 25 psi will make less power than an s2k with a t3/t67 @ 5 psi.
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  yeah i suppose if you want to get into detail,but if you match volume of the turbo and sc it should be about the same?
                                    If flow numbers are similar then psi for psi should be close.
                                    • Sweet-WRX-LovinS Offline
                                      Sweet-WRX-Lovin
                                      so anyways, very cool mods, bet it sounds badass..... vtec + turbo = wood
                                      One time...
                                        seanjohn
                                        Who is we? Is this a shop or something I don't know about?
                                          Shop is Excessive Autosports in Sioux Falls. We still haven't figured out who the bald guy is yet though. 🙂
