  2. Introductions
  3. Introductions
  4. hey i am new. whats up
142 Posts 33 Posters 13.3k Views
  • D S ohMD Offline
    D S ohMD Offline
    D S ohM
    Bp-08;276504 wrote:
    should go quad turbo
    no way. 3 cams, 3 turbos. Gotta keep a 1:1 ratio on that shiz.
    I wanna go fast!
    • Bp-08B Offline
      Bp-08B Offline
      Bp-08
      maybe 8 turbos, one for every exhaust port.
      • funky_monkey58F Offline
        funky_monkey58
        Hell man we are just going to replace the entire engine with a turbo!
        • JN210J Offline
          JN210J Offline
          JN210
          then run it on some jet fuel.
          *1989 Nissan 300ZX Z31 *
          > DelSlow;262050 wrote:
          > I like the new JN210
          • kylushK Offline
            kylushK Offline
            kylush
            with nitrous
            1998 Z28 Camaro
              no reply.. must have gone to jail?
              • C Offline
                C Offline
                Cobra Rob
                I work at walmart and we have these kind of theives in their all the time we do not have cameras in toys so they bring items to toys and open the packages and stealing anything from condoms to hand held vetc games for babies
                your going to get caught one of these days
                  Trafik Jamz
                  Nice going...you just let the world know where the vulnerability is in your organization....
                  701.541.3484
                  • 2000V8Firebird2 Offline
                    2000V8Firebird
                    this is my car
                    aka best manual driver ever ;)
                      Trafik Jamz
                      Ummm....nice car, but uhh...why in this thread?
                      701.541.3484
                        LOL n00bs
                          my oh my, noobs lately
                            Trafik Jamz
                            Haven't seen n00bs like this since...what...August of 2006?
                            701.541.3484
                            • C Offline
                              C Offline
                              Cobra Rob
                              I did not mean to give walmart secerts away but they loose tons of products from these fools
                                Watch out, they might go bankrupt...
                                • C Offline
                                  C Offline
                                  Cobra Rob
                                  yeah they told the employees fargo walmart made 20 million profit last year i think chould get a raise
                                  • D S ohMD Offline
                                    D S ohMD Offline
                                    D S ohM
                                    Must be a legendary ride? :icon_scratch:
                                    I wanna go fast!
                                      gay...
                                        2000V8Firebird
                                        cuz i didn't know where else to put it and plus i saw the first page a noob put his car up so i thought i would join him
                                          DaveH;276062 wrote:
                                          I dunno too much about Honda's, but I'd guess the clutch change would go something like this. Any honda guys correct me if I get off track:
                                          1. Jack the car up and put it on jackstands
                                          2. Unhook the lower ball joint/control arm/(whatever hondas have) enough to swing the front hubs out. Impact off the CV shaft nuts and then pull the shafts out of the hub.
                                          3. Use a small prybar to get the cv shafts out of the tranny. Unhook the shifter linkage from the trans, unhook the exhaust and any other honda doo dads you see that might keep the tranny from coming out.
                                          4. Support the engine with a jack/jackstand, and then unbolt the tranny from the chassis (I assume the trans has one of the motor motor mounts on it?). Then support the tranny with a jack, and unbolt it the trans from the engine. Use the jack to help separate the trans from the engine, then lower it and go set it somewhere out of the way.
                                          5. unbolt the pressure plate, and remove it along with the worn out clutch disk. Check the flywheel for wear/damage and go get it surfaced if it's beat up (Quality engine, M&J, etc).
                                          6. using clutch alignment tool, install the new clutch disk/pressure plate on the freshly surfaced flywheel. torque pressure plate bolts to spec.
                                          7. Install the trans back on the motor and re-hook up anything you too apart in 1-4. Take car off of jack stands.
                                          8. Start car up, rev to 8000 rpm and drop the clutch and do a smokey burnout. (new clutches like this).
                                          :icon_santa:
                                          Most of the time it's pull the engine & trans out, put the clutch in and then drop it back in... usually quicker outside the car then trying to put the trans in with the motor still in...
