  4. Flamethrowers
Flamethrowers
17 Posts 5 Posters 1.5k Views
    Schwanger
    Does anybody know anything about laws on flamethrowers. If you get caught is just going to be an exhibition?
    Reason I'm asking is I helped a friend build and install one on his Geo Metro and it turned out pretty cool so I'm thinking about doing it to my car.
    • harwood39H Offline
      harwood39H Offline
      harwood39
      how did you build it? Im very interested in one.
      I dont know about the laws, i know ive seen quite a few on older cars.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        i would assume that your car might get impounded as some sort of threat?
          harwood39H Offline
          harwood39
          My neighbor is a highway patrol man, and he said just have a switch so when there is a cop around you arent using it. He said there is some sort of fine, but he didnt specify.
          Fargo, ND 58103
          701-429-3686
            Schwanger
            Well his Geo is fuel injected but it uses a coil like any points style distributer would use so he ran a wire from the negative side of the coil to another coil that fires a spark plug in the exhaust tip (it has to be in the tip) then he welded a fuel injector (didn't actually weld the injector) into the tail pipe, put a T-fitting in the gas line (after the fuel pump), hooked it all up to two relays (have to have 2 otherwise the injector back feeds off the coil and will be open all the time) and a momentary rocker switch. But there's some technique to using it because there's not enough exygen in the exhaust to ignite the gas. If you're not moving you have to rev it up and come all the way back down to idle then it draws air into the pipe. We took it on the Interstate and hit the switch and it worked great.
            It will shoot a 2-3 foot flame when you're parked.
              harwood39H Offline
              harwood39
              Sounds pretty complicated for me, seeing how i dont weld, and i dont really want to put a hole in thw tip of my new muffler.
              Fargo, ND 58103
              701-429-3686
                Schwanger
                I was thinking about this last night. You might be able to get away with propane and move the plug farther up the pipe. But I don't know for sure, and you would get a blue flame instead of orange. You would still have some welding to do.
                  harwood39H Offline
                  harwood39
                  That would be cool, about how much did it cost? I like the idea of a blue flame. I know you can buy kits for like $125
                  Fargo, ND 58103
                  701-429-3686
                    Schwanger
                    I don't know for sure. If you did propane and wanted to do it right it would be more than 125. Unless you can find a cheap electric bottle valve. with gas you can get off cheap, all you need is a coil, old spark plug, plug wire, old injector, a couple relays, switch, and some wire.
                      harwood39H Offline
                      harwood39
                      The kit i found was for a gas one, not propane.
                      Fargo, ND 58103
                      701-429-3686
                        propane is the way to go though
                          Schwanger
                          I don't know. It's pretty cool with gas because the flames are about 3 foot long and 3 foot high, you can see the tips of the flames through the back window. Plus you can leave a little burning reminder that you were there on the ground.
                            harwood39H Offline
                            harwood39
                            but what will the gas one do to the car if its that high? I know the propane ones arent as high so the wont damage the body, and can shoot out alot farther that 3 ft.
                            Fargo, ND 58103
                            701-429-3686
                              propane is the way to go.. its eaiser to control then trying to time the mixture of your exhaust...just push the button
                                harwood39H Offline
                                harwood39
                                i take it you have experience with propane.
                                Fargo, ND 58103
                                701-429-3686
                                  is this the geo drivin around town with like taht tip that has some curve to it, my friend who also has a metro made a flame thrower kit but couldnt get any spark but when we held a lighter at the end of tip he had some that were prolly 4 feet so we tried it usuing a friends go kart racing alcohol and the flames were shittier, but it still is tight shit seeing flames from a geo, and it was the metro that has all those stickers in the back windows and its low
                                    I happen to know of a few guys who run it on their semis..ya know the 18wheeler ones. They use it to climb hills and for shits and giggles in the smoke stacks.
