  4. Flamethrowers
Flamethrowers
17 Posts 5 Posters 1.5k Views
    Schwanger
    I was thinking about this last night. You might be able to get away with propane and move the plug farther up the pipe. But I don't know for sure, and you would get a blue flame instead of orange. You would still have some welding to do.
    • harwood39H Offline
      harwood39H Offline
      harwood39
      That would be cool, about how much did it cost? I like the idea of a blue flame. I know you can buy kits for like $125
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        Schwanger
        I don't know for sure. If you did propane and wanted to do it right it would be more than 125. Unless you can find a cheap electric bottle valve. with gas you can get off cheap, all you need is a coil, old spark plug, plug wire, old injector, a couple relays, switch, and some wire.
          harwood39H Offline
          harwood39
          The kit i found was for a gas one, not propane.
          Fargo, ND 58103
          701-429-3686
            propane is the way to go though
              Schwanger
              I don't know. It's pretty cool with gas because the flames are about 3 foot long and 3 foot high, you can see the tips of the flames through the back window. Plus you can leave a little burning reminder that you were there on the ground.
                harwood39H Offline
                harwood39
                but what will the gas one do to the car if its that high? I know the propane ones arent as high so the wont damage the body, and can shoot out alot farther that 3 ft.
                Fargo, ND 58103
                701-429-3686
                  propane is the way to go.. its eaiser to control then trying to time the mixture of your exhaust...just push the button
                    harwood39H Offline
                    harwood39
                    i take it you have experience with propane.
                    Fargo, ND 58103
                    701-429-3686
                      is this the geo drivin around town with like taht tip that has some curve to it, my friend who also has a metro made a flame thrower kit but couldnt get any spark but when we held a lighter at the end of tip he had some that were prolly 4 feet so we tried it usuing a friends go kart racing alcohol and the flames were shittier, but it still is tight shit seeing flames from a geo, and it was the metro that has all those stickers in the back windows and its low
                        I happen to know of a few guys who run it on their semis..ya know the 18wheeler ones. They use it to climb hills and for shits and giggles in the smoke stacks.
