  4. Built in Fuzzbusters?
15 Posts 10 Posters 1.2k Views
  • F Offline
    F Offline
    FloppedDaNuts
    I am looking for a fuzz buster, that could be integrated into the dash. My wife's old Lexus had one and was a factory option, I liked the way it acted and was seamless.
    Any recommendations?
      really?
        I like the factory ones. Their clean
          peanut butter is awesome.
            Trafik Jamz
            K-40 makes one of the best discreet mount radar detectors I've seen. I can check my sources and see if I can get them for you if you like.
            701.541.3484
              Get a V1. Place at top of windshield, and hardwire it.
              • F Offline
                F Offline
                FloppedDaNuts
                Chuck helped me out, and we had a good talk over the phone. Thanks again Chuck!
                • D S ohMD Offline
                  D S ohMD Offline
                  D S ohM
                  trafik jamz;278729 wrote:
                  k-40 makes one of the best discreet mount radar detectors i've seen. I can check my sources and see if i can get them for you if you like.
                  k-40 ftw!
                  I wanna go fast!
                  • legacy-user-33L Offline
                    legacy-user-33
                    Check out the Valentine 1. It comes with a dash friendly display..
                    http://www.valentine1.com/
                    -Tin-
                    -IS300-Black on Gold-
                      ^The "dash friendly" display is not included. Its like an extra $50
                        so you can read english
                          I bet your wishing you woulda had that fuzz buster now huh? Lol
                            thrash
                            If you're looking at something for a CAN-BUS VAG car (like the R8), you can even do one better with a Valentine1.
                            (from http://techreactions.com/default.aspx, but i think i've seen a better/different one before)
                            People have figured out how to build an adapter for the V1 remote display to the Audi FIS [the little LCD between your speedo and tacho].
                            Viola -- factory radar detector 🙂
                            the thing holding me back from a radar is to get the best actual protection, the answer is V1 hands down [plus a laser jammer, ala the Laser Park Pro]. But the V1 isn't a concealed / distributed system. I don't want anything stuck to my windshield. Passport SRX puts a network of sensors all over the car and has split the system into its constituent parts. Much more "permanant" install. But, the sensors should be as high as possible, ideally, and so the radar performance is somewhat compromised.
                            If Mike Valentine would make a box that is as good as his current box, but it was cut up in the following way
                            • sensor mounted on back side of rear-view mirror for for-ward looking radar
                            • sensor mounted on 3rd brake light for rear-looking radar
                            • button/knob interface panel that can be mounted anywhere in the car
                            • display panel that can be mounted anywhere in the car
                            • laser sensors for front and rear licence plate areas
                            • data output port for interfacing to external displays and sending laser warning signals [to interface with an LPP or other jamming device]
                            Then I'd probably buy one 🙂
                            • F Offline
                              F Offline
                              FloppedDaNuts
                              Thanks for your help thrash, Chuck has already assisted me and since he can do installation I will be going through him.
                                Trafik Jamz
                                I can check and see if I can get V1's...I always forget about them
                                701.541.3484
