  4. dart blocks
dart blocks
20 Posts 7 Posters 10.8k Views
  • bluejaysB Offline
    bluejaysB Offline
    bluejays
    i have just recently learned about dart blocks. i was curious what are the advantages of them? what are the disadvantages? and how do you decide what deck size and overbore you want?
      bigger the bore...the more power you can make...think of dart blocks like a TRE or Dogbox transmission = Bulletproof
      • bluejaysB Offline
        bluejaysB Offline
        bluejays
        so the only downfall is the price? you don't lose drivability or anything?
          lol i wouldnt say any DSM transmission is bulletproof...thats gettin too cocky...trust me i know 🙂
            no they can be used in DD cars...from what i have heard and seen they are really good and worth the price.
            • bluejaysB Offline
              bluejaysB Offline
              bluejays
              sweet
                Dart blocks are pretty cool until you figure out everything you need to make it work. 🙂
                Dart Block, Crank, Bearings, Oil Squirters, Pistons, and Rods makes that bottom end price go up pretty quick. 🙂
                • bluejaysB Offline
                  bluejaysB Offline
                  bluejays
                  ya, is it worth it though nick, especially if you plan on boosting it?
                    talk to Dartcivic if you wanna hear stories about dart blocks......
                      Sleeved stock b series motor is just fine. Good condition B series cranks can be hard to come by. If you are looking into having a motor sleeved let me know.
                        seanjohn
                        With a dart block you won't ever have to worry about sinking sleeves. Also, there are just two different size blocks, the short and tall deck. Short is the b16, tall is the rest of the B-series motors.
                          Uhm. You just need the right kind of sleeves to not have to worry about sleeves sinking. 😉
                            seanjohn
                            Any sleeve....benson darton GE AEBS all have a chance of sinking. If you're gonna go all out, might as well go Dart.
                              Any sleeve? Have you seen the design of the AEBS sleeve? It's shaped like a T... Sits on top of a ledge. Hard to sink when it's got a lip butted up against something.
                              I've been "all out" for almost 4 years now. I have AEBS sleeves in my motor, and have used them in two other motors for others as well. Also, all pro cars use OEM honda blocks w/ aftermarket sleeves @ HP levels approaching 1200-1300 whp. Dart block isn't worth it IMHO.
                              • tntmstrT Offline
                                tntmstrT Offline
                                tntmstr
                                Actually, I would have to agree with GSR for once. We are a dealer of AEBs and Dart. I would rather sell someone AEBS. IMHO
                                Jason Christopherson
                                Store Manager
                                Tintmasters
                                Fargo, ND (701)239-TINT
                                www.tintmasters.net
                                • bluejaysB Offline
                                  bluejaysB Offline
                                  bluejays
                                  how much boost could a well built oem block hold? how much boost could a well built dart hold?
                                    its not how much boost it can hold, its how long that much boost will stay reliable
                                      My AEBS motor has seen in excess of 30 psi with zero problems. Boost pressure isn't the killer, detonation is the killer.
                                      A stock LS block can and has dealt with 25+ psi no problem. It is all in the tune. Even a well bult AEBS block can grenade if the tune is that bad.
                                      • tntmstrT Offline
                                        tntmstrT Offline
                                        tntmstr
                                        not saying that the dart block is a bad thing. Just that the stock block and AEBS sleeving is just more economical. And has some pretty high tolerances
                                           Same material used in top fuel cars
                                        Successfully tested to 55 lbs. of boost
                                        "Best engineered sleeve" ... Sport Compact Car
                                        AEBS Final Bore and Hone $200
                                        AEBS Stainless O-Ring Work $200
                                        AEBS T-Sleeve Engine Work $1075
                                        not bad for $1475 and the cost of a stock block $150-$200
                                        if you want to take a look at an AEBS sleeved/ o-ringed block.... drop by the Fargo shop before we put the head on.
                                        Store Manager
                                        Tintmasters
                                        www.tintmasters.net
                                          Wow I didn't know I still had these pictures of my motor. Good shot of AEBS sleeves and o-rings.
