  4. Good day at the dyno
33 Posts 21 Posters 2.1k Views
    i'm already at 41 psi baseline fuel, i'm afraid the pump is going to run out of steam at high boost the way it is.
    The red car dyno'd around 600 rwhp. I never had much luck with it on the dyno.
    Had a relatively crappy day at th track today, or maybe it's jut been a slow learing process. First pass i launched fairly hard, banged off the wheelie bars and unloaded the rear end... spinning all over at that point. A marvelous 1.9 6"l led to a 9.0 @ 1.63. Turned up the boost a bit and adjusted the wheelie bar, flubbed the launch and had no boost out of th hole ( pro tree can be a bugger), ran a 8.73 @ 165. Last pass I turned the boost up a tad more (36 psi finally), but the car hickuped at the launch, shitty 60' and ran a 8.51 @ 168.
    The good thing was the traps 168 on 36 psi of boost, where last year it took 42 psi plus 150 shot.
    • XJHEADX Offline
      XJHEADX Offline
      Yep, I just looked at the charts, the Weldons do not like a lot of pressure. It looks like I may have to go back to my ACCEL pump and dump the 2035. The Accel draws a lot less amperage too. Doesn't make sense to me.
      • funky_monkey58F Offline
        funky_monkey58
        Get that thing dialed in a bit more with some seat time and you will be there.
        • C Offline
          C Offline
          Cobra Rob
          hp oh yeah
            dave you should have more than enough pump, i would get rid of the 440s and put a set of 750s in there and keep the pressure down.
              12x1000cc and let her buck.
                funky_monkey58
                Wouldn't that be the same amount of fuel at WOT?
                  http://injectordynamics.com/
                    funky_monkey58
                    ^ I take it you also have been on site when injectors are flow tested?
                      This is what I think is cool
                      DaveH;279863 wrote:
                      Then we did some wastegate (17 psi) pulls. It made 630 rwhp.
                      lol through a big stall, glide, and rearend
                        I was really surprised it made that much power at 17 psi also. 🙂
                          video
                          [ame]http://www.youtube.com/watch?v=KoXedpDRPFE[/ame]
                            told you that high compression would kick ass! good job
                            • XJHEADX Offline
                              XJHEADX Offline
                              nevermind works now
                                XJHEAD;280082 wrote:
                                nevermind works now
                                Get yours to work?
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  DaveH;280084 wrote:
                                  Get yours to work?
                                  Same thing again, no vid until 58 into it. ???? 2 hours to upload both times
                                  • z31Z Offline
                                    z31Z Offline
                                    z31
                                    828 torque :icon_thumright: High Compression FTW
                                      yeah, you sure told him.
                                      • capitljC Offline
                                        capitljC Offline
                                        capitlj
                                        schwing
                                        > Mitch Hedberg wrote:
                                        2004 Impala LS 3.8
