  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 15.9k Views
  • z31Z Offline
    z31Z Offline
    z31
    The car is now running/tuned on e85.:icon_cheers:
    9:1 compression pistons 14LBS of boost with no intercooler on a 85 degree day. :icon_bigsmurf:
    • fdfreakF Offline
      fdfreakF Offline
      fdfreak
      very nice
      12.645@118mph 12.6psi
      • funky_monkey58F Offline
        funky_monkey58
        Street tune or dyno?
        • fdfreakF Offline
          fdfreakF Offline
          fdfreak
          what size injectors are you using to run e85?
            Add the intercooler! No reason not to!
            • z31Z Offline
              z31Z Offline
              z31
              Gary and I did the tune. :icon_bigsmurf:
              • z31Z Offline
                z31Z Offline
                z31
                I'm currently using 560cc EVO fuel injectors.
                • z31Z Offline
                  z31Z Offline
                  z31
                  When i Finnish the piping i will install it.
                  • C Offline
                    C Offline
                    Cobra Rob
                    keep up the good work
                      funky_monkey58
                      You trusted that redneck tuning your car?!:icon_salut:
                      • kylushK Offline
                        kylushK Offline
                        kylush
                        Says the guy with the blown motor tacoed hood and f'd up roof....
                        1998 Z28 Camaro
                          OMG lol
                          • z31Z Offline
                            z31Z Offline
                            z31
                            To get it in the ball Park.:icon_salut: I did a few adjustments after reading on the online Nistune tuning instructions and Nistune Forum. Thanx for the help on getting started on e85 Bill O. :icon_bigsmurf:
                            • z31Z Offline
                              z31Z Offline
                              z31
                              My best 1/4 mile run at Brainerd International Race way
                              Modern Auto Performance Proving Grounds Event;
                              60 .... 1.89
                              330 .... 5.45
                              1/8 .... 8.42
                              MPH.... 84.1
                              1000....10.9
                              1/4......13.0
                              MPH.....106
                              • z31Z Offline
                                z31Z Offline
                                z31
                                New stuff. A Fidanza Aluminum 11 LB Flywheel and a South Bend DXD Stage 6 FE-X Clutch utilizing a modified 350Z pressure plate (SS-X) which delivers 2700lbs of clamp load with an unbelievable light pedal. :icon_bigsmurf:
                                • fdfreakF Offline
                                  fdfreakF Offline
                                  fdfreak
                                  Nice to see you finally got a new one. I know the old clutch was giving you issues late last summer.
                                  • z31Z Offline
                                    z31Z Offline
                                    z31
                                    The South Bend DXD stage 3 was a really good clutch. The problem was that my motor was making a lot more torque at low boost than what the clutch was rated for. :icon_bigsmurf:
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      Here are some more current pictures of my intercooler install.
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        Intercooler install.:icon_bigsmurf:
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          My track times at Interstate dragways, Sabin MN Sunday August 8:
                                          My two best runs on 10lbs boost was
                                          [email protected].... 2.02 60ft
                                          [email protected].... 1.99 60ft
                                          My 4 best runs on 12-13lbs boost was
                                          [email protected] 60ft
                                          My best run at 15lbs boost was
                                          12-13 lbs boost
                                          http://www.youtube.com/watch?v=JF76ETa951Y
                                          http://www.youtube.com/watch?v=DCWa6BlQKQ0
                                          15 lbs boost
                                          http://www.youtube.com/watch?v=B0f4jqPBE20
                                          Race weight was 3500lbs 58mm turbo, drag radials on E85.
                                          Ported and polished heads with 270H cams 3in exhaust.
