  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • PSiedTSiP
    PSiedTSiP
    z31;280147 wrote:
    The car is now running/tuned on e85.:icon_cheers:
    9:1 compression pistons 14LBS of boost with no intercooler on a 85 degree day. :icon_bigsmurf:
    Add the intercooler! No reason not to!
    spanish-rice;237125 wrote:
    • z31Z
      z31Z
      z31
      funky_monkey58;280166 wrote:
      Street tune or dyno?
      Gary and I did the tune. :icon_bigsmurf:
      • z31Z
        z31Z
        z31
        fdfreak;280170 wrote:
        what size injectors are you using to run e85?
        I'm currently using 560cc EVO fuel injectors.
        • z31Z
          z31Z
          z31
          When i Finnish the piping i will install it.
          • C
            C
            Cobra Rob
            keep up the good work
            • funky_monkey58F
              funky_monkey58F
              funky_monkey58
              You trusted that redneck tuning your car?!:icon_salut:
              • kylushK
                kylushK
                kylush
                Says the guy with the blown motor tacoed hood and f'd up roof....
                1998 Z28 Camaro
                • GrrG
                  GrrG
                  OMG lol
                  • z31Z
                    z31Z
                    z31
                    To get it in the ball Park.:icon_salut: I did a few adjustments after reading on the online Nistune tuning instructions and Nistune Forum. Thanx for the help on getting started on e85 Bill O. :icon_bigsmurf:
                    • z31Z
                      z31Z
                      z31
                      My best 1/4 mile run at Brainerd International Race way
                      Modern Auto Performance Proving Grounds Event;
                      60 .... 1.89
                      330 .... 5.45
                      1/8 .... 8.42
                      MPH.... 84.1
                      1000....10.9
                      1/4......13.0
                      MPH.....106
                      • z31Z
                        z31Z
                        z31
                        New stuff. A Fidanza Aluminum 11 LB Flywheel and a South Bend DXD Stage 6 FE-X Clutch utilizing a modified 350Z pressure plate (SS-X) which delivers 2700lbs of clamp load with an unbelievable light pedal. :icon_bigsmurf:
                        • fdfreakF
                          fdfreakF
                          fdfreak
                          Nice to see you finally got a new one. I know the old clutch was giving you issues late last summer.
                          12.645@118mph 12.6psi
                          • z31Z
                            z31Z
                            z31
                            The South Bend DXD stage 3 was a really good clutch. The problem was that my motor was making a lot more torque at low boost than what the clutch was rated for. :icon_bigsmurf:
                            • z31Z
                              z31Z
                              z31
                              Here are some more current pictures of my intercooler install.
                              • z31Z
                                z31Z
                                z31
                                Intercooler install.:icon_bigsmurf:
                                • z31Z
                                  z31Z
                                  z31
                                  My track times at Interstate dragways, Sabin MN Sunday August 8:
                                  My two best runs on 10lbs boost was
                                  [email protected].... 2.02 60ft
                                  [email protected].... 1.99 60ft
                                  My 4 best runs on 12-13lbs boost was
                                  [email protected] 60ft
                                  My best run at 15lbs boost was
                                  12-13 lbs boost
                                  http://www.youtube.com/watch?v=JF76ETa951Y
                                  http://www.youtube.com/watch?v=DCWa6BlQKQ0
                                  15 lbs boost
                                  http://www.youtube.com/watch?v=B0f4jqPBE20
                                  Race weight was 3500lbs 58mm turbo, drag radials on E85.
                                  Ported and polished heads with 270H cams 3in exhaust.
                                  • wesholeW
                                    wesholeW
                                    What rpm's you shifting at Jason?
                                    • z31Z
                                      z31Z
                                      z31
                                      weshole;314771 wrote:
                                      what rpm's you shifting at jason?
                                      6000 rpm
                                      • wesholeW
                                        wesholeW
                                        Why so low?
                                        • z31Z
                                          z31Z
                                          z31
                                          weshole;314774 wrote:
                                          Why so low?
                                          6200 is where the cam drops off in power.
