  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • z31Z
    z31Z
    z31
    My best 1/4 mile run at Brainerd International Race way
    Modern Auto Performance Proving Grounds Event;
    60 .... 1.89
    330 .... 5.45
    1/8 .... 8.42
    MPH.... 84.1
    1000....10.9
    1/4......13.0
    MPH.....106
    • z31Z
      z31Z
      z31
      New stuff. A Fidanza Aluminum 11 LB Flywheel and a South Bend DXD Stage 6 FE-X Clutch utilizing a modified 350Z pressure plate (SS-X) which delivers 2700lbs of clamp load with an unbelievable light pedal. :icon_bigsmurf:
      • fdfreakF
        fdfreakF
        fdfreak
        Nice to see you finally got a new one. I know the old clutch was giving you issues late last summer.
        12.645@118mph 12.6psi
        • z31Z
          z31Z
          z31
          The South Bend DXD stage 3 was a really good clutch. The problem was that my motor was making a lot more torque at low boost than what the clutch was rated for. :icon_bigsmurf:
          • z31Z
            z31Z
            z31
            Here are some more current pictures of my intercooler install.
            • z31Z
              z31Z
              z31
              Intercooler install.:icon_bigsmurf:
              • z31Z
                z31Z
                z31
                My track times at Interstate dragways, Sabin MN Sunday August 8:
                My two best runs on 10lbs boost was
                [email protected].... 2.02 60ft
                [email protected].... 1.99 60ft
                My 4 best runs on 12-13lbs boost was
                [email protected] 60ft
                My best run at 15lbs boost was
                12-13 lbs boost
                http://www.youtube.com/watch?v=JF76ETa951Y
                http://www.youtube.com/watch?v=DCWa6BlQKQ0
                15 lbs boost
                http://www.youtube.com/watch?v=B0f4jqPBE20
                Race weight was 3500lbs 58mm turbo, drag radials on E85.
                Ported and polished heads with 270H cams 3in exhaust.
                • wesholeW
                  wesholeW
                  What rpm's you shifting at Jason?
                  • z31Z
                    z31Z
                    z31
                    weshole;314771 wrote:
                    what rpm's you shifting at jason?
                    6000 rpm
                    • wesholeW
                      wesholeW
                      Why so low?
                      • z31Z
                        z31Z
                        z31
                        weshole;314774 wrote:
                        Why so low?
                        6200 is where the cam drops off in power.
                        • z31Z
                          z31Z
                          z31
                          The car has a basic tune in it, so the tuneup is not ideal. I'm gonna have the car dyno tuned to fine tune the timing and fuel to gain some power in all RPM ranges. Hopefully i can get another 50 horse out of it with timing and fuel adjustments and a little more boost.
                          • wesholeW
                            wesholeW
                            I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
                            • PSiedTSiP
                              PSiedTSiP
                              Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
                              spanish-rice;237125 wrote:
                              • z31Z
                                z31Z
                                z31
                                Ya, i guess i could try going to 7000 rpm next time im at the track.
                                • wesholeW
                                  wesholeW
                                  I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
                                  • GrrG
                                    GrrG
                                    that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
                                    • PSiedTSiP
                                      PSiedTSiP
                                      what RPM does he drop to when it shifts?
                                      • GrrG
                                        GrrG
                                        about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                                        • z31Z
                                          z31Z
                                          z31
                                          I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                                          gear 1-2....1700 rpm
                                          gear 2-3....1100 rpm
                                          gear 3-4....800 rpm
                                          gear 4-5.... 500 rpm
                                          This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
