  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • fdfreakF
    fdfreakF
    fdfreak
    Nice to see you finally got a new one. I know the old clutch was giving you issues late last summer.
    12.645@118mph 12.6psi
    • z31Z
      z31Z
      z31
      The South Bend DXD stage 3 was a really good clutch. The problem was that my motor was making a lot more torque at low boost than what the clutch was rated for. :icon_bigsmurf:
      • z31Z
        z31Z
        z31
        Here are some more current pictures of my intercooler install.
        • z31Z
          z31Z
          z31
          Intercooler install.:icon_bigsmurf:
          • z31Z
            z31Z
            z31
            My track times at Interstate dragways, Sabin MN Sunday August 8:
            My two best runs on 10lbs boost was
            [email protected].... 2.02 60ft
            [email protected].... 1.99 60ft
            My 4 best runs on 12-13lbs boost was
            [email protected] 60ft
            My best run at 15lbs boost was
            12-13 lbs boost
            http://www.youtube.com/watch?v=JF76ETa951Y
            http://www.youtube.com/watch?v=DCWa6BlQKQ0
            15 lbs boost
            http://www.youtube.com/watch?v=B0f4jqPBE20
            Race weight was 3500lbs 58mm turbo, drag radials on E85.
            Ported and polished heads with 270H cams 3in exhaust.
            • wesholeW
              wesholeW
              What rpm's you shifting at Jason?
              • z31Z
                z31Z
                z31
                weshole;314771 wrote:
                what rpm's you shifting at jason?
                6000 rpm
                • wesholeW
                  wesholeW
                  Why so low?
                  • z31Z
                    z31Z
                    z31
                    weshole;314774 wrote:
                    Why so low?
                    6200 is where the cam drops off in power.
                    • z31Z
                      z31Z
                      z31
                      The car has a basic tune in it, so the tuneup is not ideal. I'm gonna have the car dyno tuned to fine tune the timing and fuel to gain some power in all RPM ranges. Hopefully i can get another 50 horse out of it with timing and fuel adjustments and a little more boost.
                      • wesholeW
                        wesholeW
                        I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
                        • PSiedTSiP
                          PSiedTSiP
                          Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
                          spanish-rice;237125 wrote:
                          • z31Z
                            z31Z
                            z31
                            Ya, i guess i could try going to 7000 rpm next time im at the track.
                            • wesholeW
                              wesholeW
                              I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
                              • GrrG
                                GrrG
                                that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
                                • PSiedTSiP
                                  PSiedTSiP
                                  what RPM does he drop to when it shifts?
                                  • GrrG
                                    GrrG
                                    about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                                    • z31Z
                                      z31Z
                                      z31
                                      I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                                      gear 1-2....1700 rpm
                                      gear 2-3....1100 rpm
                                      gear 3-4....800 rpm
                                      gear 4-5.... 500 rpm
                                      This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
                                      • wesholeW
                                        wesholeW
                                        Im assuming the Green is the HP and the blue is the TQ. If that's the case, theres a lot more rpms avail.
                                        • beachbum_jonB
                                          beachbum_jonB
                                          beachbum_jon
                                          judging by that dyno graph, and given that your car makes the same power at the same rpms, shifting at 6200 is about perfect IMO. Why go past that when your power drops off, when you can shift and be right back in the power again?
                                          -John Adams, 1735-1826-
