  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 14.8k Views
  • z31Z Offline
    z31Z Offline
    z31
    weshole;314774 wrote:
    Why so low?
    6200 is where the cam drops off in power.
    • z31Z Offline
      z31Z Offline
      z31
      The car has a basic tune in it, so the tuneup is not ideal. I'm gonna have the car dyno tuned to fine tune the timing and fuel to gain some power in all RPM ranges. Hopefully i can get another 50 horse out of it with timing and fuel adjustments and a little more boost.
        I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
          Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
          • z31Z Offline
            z31Z Offline
            z31
            Ya, i guess i could try going to 7000 rpm next time im at the track.
              I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
                that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
                  what RPM does he drop to when it shifts?
                    about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                    • z31Z Offline
                      z31Z Offline
                      z31
                      I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                      gear 1-2....1700 rpm
                      gear 2-3....1100 rpm
                      gear 3-4....800 rpm
                      gear 4-5.... 500 rpm
                      This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
                        Im assuming the Green is the HP and the blue is the TQ. If that's the case, theres a lot more rpms avail.
                        • beachbum_jonB Offline
                          beachbum_jon
                          judging by that dyno graph, and given that your car makes the same power at the same rpms, shifting at 6200 is about perfect IMO. Why go past that when your power drops off, when you can shift and be right back in the power again?
                          -John Adams, 1735-1826-
                          • z31Z Offline
                            z31Z Offline
                            z31
                            Yes.
                            • BookemB Offline
                              BookemB Offline
                              Bookem
                              I'm guessing since Jason has higher compression and less boost his power band is lower rpm just a bit more power.
                              Legacy GT
                              Gmc Suburban
                              Hallorann: Fargostreet?
                              Hallorann: No, I ain't.
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Im currently installing manual trans number 3
                                • JN210J Offline
                                  JN210J Offline
                                  JN210
                                  fun? why do they keep breaking?
                                  *1989 Nissan 300ZX Z31 *
                                  > DelSlow;262050 wrote:
                                  > I like the new JN210
                                  • funky_monkey58F Offline
                                    funky_monkey58
                                    Because the big doof can't drive.
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      ^^^^Look who's talking!
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        Next victom. This is a 87-89 Z31 Turbo: FS5R30A: Nissan Turbo 5spd
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          Jeff, im sure its the hard hitting DXD stage 6 clutch and the big power gain from the motor that is destroying the Borg Warner T-5s. The DXD stage 3 saved on the T-5s because it slipped a little when it engaged.
