  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 16.1k Views
  • wesholeW
    wesholeW
    z31;314779 wrote:
    6200 is where the cam drops off in power.
    I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
    • PSiedTSiP
      PSiedTSiP
      Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
      spanish-rice;237125 wrote:
      • z31Z
        z31Z
        z31
        Ya, i guess i could try going to 7000 rpm next time im at the track.
        • wesholeW
          wesholeW
          I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
          • GrrG
            GrrG
            that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
            • PSiedTSiP
              PSiedTSiP
              what RPM does he drop to when it shifts?
              • GrrG
                GrrG
                about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                • z31Z
                  z31Z
                  z31
                  I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                  gear 1-2....1700 rpm
                  gear 2-3....1100 rpm
                  gear 3-4....800 rpm
                  gear 4-5.... 500 rpm
                  This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
                  • wesholeW
                    wesholeW
                    Im assuming the Green is the HP and the blue is the TQ. If that's the case, theres a lot more rpms avail.
                    • beachbum_jonB
                      beachbum_jonB
                      beachbum_jon
                      judging by that dyno graph, and given that your car makes the same power at the same rpms, shifting at 6200 is about perfect IMO. Why go past that when your power drops off, when you can shift and be right back in the power again?
                      -John Adams, 1735-1826-
                      • z31Z
                        z31Z
                        z31
                        Yes.
                        • BookemB
                          BookemB
                          Bookem
                          I'm guessing since Jason has higher compression and less boost his power band is lower rpm just a bit more power.
                          Legacy GT
                          Gmc Suburban
                          Hallorann: Fargostreet?
                          Hallorann: No, I ain't.
                          • z31Z
                            z31Z
                            z31
                            Im currently installing manual trans number 3
                            • JN210J
                              JN210J
                              JN210
                              fun? why do they keep breaking?
                              *1989 Nissan 300ZX Z31 *
                              DelSlow;262050 wrote:
                              I like the new JN210
                              • funky_monkey58F
                                funky_monkey58F
                                funky_monkey58
                                Because the big doof can't drive.
                                • z31Z
                                  z31Z
                                  z31
                                  ^^^^Look who's talking!
                                  • z31Z
                                    z31Z
                                    z31
                                    Next victom. This is a 87-89 Z31 Turbo: FS5R30A: Nissan Turbo 5spd
                                    • z31Z
                                      z31Z
                                      z31
                                      Jeff, im sure its the hard hitting DXD stage 6 clutch and the big power gain from the motor that is destroying the Borg Warner T-5s. The DXD stage 3 saved on the T-5s because it slipped a little when it engaged.
                                      • JN210J
                                        JN210J
                                        JN210
                                        oh ok lol
                                        • z31Z
                                          z31Z
                                          z31
                                          New parts. Precision 880cc fuel injectors.
