  4. Z31 Introduction
Z31 Introduction
107 Posts 22 Posters 15.9k Views
  • z31Z Offline
    z31Z Offline
    z31
    Intercooler install.:icon_bigsmurf:
    • z31Z Offline
      z31Z Offline
      z31
      My track times at Interstate dragways, Sabin MN Sunday August 8:
      My two best runs on 10lbs boost was
      [email protected].... 2.02 60ft
      [email protected].... 1.99 60ft
      My 4 best runs on 12-13lbs boost was
      [email protected] 60ft
      My best run at 15lbs boost was
      12-13 lbs boost
      http://www.youtube.com/watch?v=JF76ETa951Y
      http://www.youtube.com/watch?v=DCWa6BlQKQ0
      15 lbs boost
      http://www.youtube.com/watch?v=B0f4jqPBE20
      Race weight was 3500lbs 58mm turbo, drag radials on E85.
      Ported and polished heads with 270H cams 3in exhaust.
        What rpm's you shifting at Jason?
        • z31Z Offline
          z31Z Offline
          z31
          weshole;314771 wrote:
          what rpm's you shifting at jason?
          6000 rpm
            Why so low?
            • z31Z Offline
              z31Z Offline
              z31
              weshole;314774 wrote:
              Why so low?
              6200 is where the cam drops off in power.
              • z31Z Offline
                z31Z Offline
                z31
                The car has a basic tune in it, so the tuneup is not ideal. I'm gonna have the car dyno tuned to fine tune the timing and fuel to gain some power in all RPM ranges. Hopefully i can get another 50 horse out of it with timing and fuel adjustments and a little more boost.
                  I cant imagine the drop off is that drastic that you wont still pull hard if you rev higher.
                    Agreed. Holding the previous gear a little longer can help you get into your mid range power in the next gear. It may also be beneficial to adjust shift times in every gear.
                    • z31Z Offline
                      z31Z Offline
                      z31
                      Ya, i guess i could try going to 7000 rpm next time im at the track.
                        I think your car is faster than you showed and it sure seemed that you were definitely shifting way too soon.
                          that car drops 100hp from 6200-7000. His tq peak is about 4400, shifting any later than 6200 would be a complete waste of time and slow the car down alot.
                            what RPM does he drop to when it shifts?
                              about 4400, shifting at 6200 is about perfect. It really needs a bigger turbine and more cam, but the turbine and housing is killing a solid 40hp up top
                              • z31Z Offline
                                z31Z Offline
                                z31
                                I have been thinking about this. I took a look at the rpm drop on each shift, and this is what i came up with:
                                gear 1-2....1700 rpm
                                gear 2-3....1100 rpm
                                gear 3-4....800 rpm
                                gear 4-5.... 500 rpm
                                This is a dyno sheet of the same setup in another z31. The only differance is im using e85 at 15 lbs of boost with 9:1 compression pistons and, he is using 93oct at 20 lbs of boost with 7.8:1 compression pistons.
                                  Im assuming the Green is the HP and the blue is the TQ. If that's the case, theres a lot more rpms avail.
                                  • beachbum_jonB Offline
                                    beachbum_jon
                                    judging by that dyno graph, and given that your car makes the same power at the same rpms, shifting at 6200 is about perfect IMO. Why go past that when your power drops off, when you can shift and be right back in the power again?
                                    -John Adams, 1735-1826-
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      Yes.
                                      • BookemB Offline
                                        BookemB Offline
                                        Bookem
                                        I'm guessing since Jason has higher compression and less boost his power band is lower rpm just a bit more power.
                                        Legacy GT
                                        Gmc Suburban
                                        Hallorann: Fargostreet?
                                        Hallorann: No, I ain't.
                                        • z31Z Offline
                                          z31Z Offline
                                          z31
                                          Im currently installing manual trans number 3
