  4. ipod debate issues
ipod debate issues
12 Posts 4 Posters 1.0k Views
    i'm trying to find a 5th gen with a damaged screen (obviously, because it would be cheaper) so i can do some tinkering.
    • F Offline
      F Offline
      FloppedDaNuts
      A bit perplexed then of what your question exactly is? Within the same post, you also show the resolution, the 5th generation Ipod and the one shown in the tutorial , would work the same.
      Are your questions more relating to the actual process of opening the ipod up? If so, there are plenty of tutorials on that process specifically out there.
        lol how did you get that out of his OP..... i think he has that covered
        • F Offline
          F Offline
          FloppedDaNuts
          ..Then what's the question? I'm reaching for straws here. He pretty much covered everything in the OP.
            i guess i didn't specify a couple of things.
            since this is a debate, i assumed everyone would understand that the other side of the debate is the converse of my arguments: the larger drive would not be recognized in the same way because of the need for a firmware update (or something similar), and using various connectors to attach a sata drive would not work for (approximately) the same reason.
              Using a larger HD in an iPod is no problem, but for bigger drives you need to source a different power supply.
              Standard drives inside the iPods are 1.8inch drives, although I'm sure you could rig up some adapter to use larger IDE drives. Its POSSIBLE, maybe, to use a sata drive using a SATA / IDE adapter inbetween.
              You can also put different firmware on there:
              http://www.rockbox.org/
              Whats the point of it if you lose portability though?
                with my car stereo, an external usb hdd takes about 20 seconds to be recognized and for music to start playing. with an ipod, it's much faster (probably because of the index), and there are more options. unless i find a way to keep the deck powered through ignition (i stop the engine at long lights, it improves my mileage by almost 10%) without running a wire to a toggle switch and then the deck, this seems like the better way go.
                given this situation, i would be interested in other ideas that anyone can offer, but i'm still interested in finding a way to get a sata drive to function with an ipod (for geek value, if nothing else)
                  http://www.cooldrives.com/ide-to-sata.html
                  http://www.cooldrives.com/ide-ata-adapter-sata-hard-drive-adapter.html
                  You would need one of those, as well as an external DC power supply for the drive itself, and then you'd have to match the pins and solder wires or use that second link's adapter.
                  Not to mention most SATA drives will die in a car, unless you are using SSD or something of that nature. It's way more cost / effort then it's worth IMO.
                    lol i love it when jim lays it down
                      i found some stuff on addonics.com that looks like it will be useful, but i haven't decided for sure. i'll browse around those other sites.
                      i was planning to use some sort of shock absorbing system, but i am still a little unsure at this point. i'm leaning toward a laptop drive, and i'm currently doing some experimenting with one in an external enclosure, but it's just connected as a usb, fat32 device.
                      until the cost gets above $1.875/gb for 160+, it's still cheaper than a 160gb ipod.
                      lays it down? you mean, gives what you expect to be the final word? hardly. as a fellow geek, i value his opinions and ideas.
