compression test gone wrong
MisterCMK;283900 wrote:
Try soaking it with Kroil or a similar penetrating oil.KY...
weshole;283928 wrote:
bring him some from your personal stash.i only use 5w-30 mobil1
Joel;283866 wrote:
the hose is stuck on too... the tester I had is only 2 pieces afaik, The dial indicator comes off and the hose and threaded fitting are all in one piece.keep twisting as much as you can and see if it frees up, if not pull really hard and try pop the hose part off (cant make it any worse), then there should be a "nipple" exposed that was holding the hose on, take a 1/4 rachet (sp) 1/4 long extension, and a 7/32 socket.... pound the socket on the "nipple" and try loosening it.... this is what i did to mine when it got stuck haha although mine was in three parts so idk if that helped me or not
