  3. Track Talk
  4. Well we finally went to the track with the blue car.
24 Posts 10 Posters 3.8k Views
  • funky_monkey58F Offline
    funky_monkey58
    Well we finally took my uncles car to the track to see what ballpark we are in and we are pretty happy with the results so far.
    This is the car.
    Time slip.
    Dyno graph.
    The runs were all on 18" rims with dirreza tires. And the only mod we have for traction is suprasport traction bars.
    I also personally ran the car down the strip once and got a 12.58 at 121mph.
    This was my uncles first time ever driving at the strip. We are thinking with more practice and a few more pounds of boost 11's are at hand.
      Sweet! Congrats guys. What was the 60' time?
      This is the car.
      Time slip.
      Dyno graph.
        funky_monkey58
        2.096 60ft for Dans best pass.
        And I cut a 2.3 60ft taking it easy on it. (it's better when the owner of the car breaks it)
        This was all on the 18" street tires.
        • C Offline
          C Offline
          Cobra Rob
          nice ride and time:icon_salut:
            your trapping 120mph with 550whp??
              Tire spinnin mofo im figuring.
                still....
                is that thing a tank or what?
                  yeah its like 3600lbs or so. Trust me it has more in it than that, when we were out driving around in it, i can say it would have given my TA a run
                    funky_monkey58
                    Just wait until next year should be even more fun with a bigger turbo, and a custom intake manifold.
                      aliengotpsi
                      thats an easy 11 car as is.. 2.0 60 foot is really bad.. id say its close to a 11.5-11.6 car with a 1.7 60 foot.
                      does it make 550 hp on a DD dyno converted to Dynojet numbers? if not thats close to 640 hp.. on a Dynojet.. How much boost are you running.? What fuel? What turbos
                      IF you want we can do a roll on against my EVO which has ran a shitty best of 11.3@ 126 1.7 60 foots made 535hp 470 TQ on 30 psi w/ E85
                      Kevin Smith
                      Straightlinedetailing.com
                        funky_monkey58
                        GT3582R turbo A1000 fuel pump with a sumped tank, -8 feed line -6 return, 1200cc injectors, E85. Tuned on Shanes dyno at DB. So it was on a dynodynamics at 22psi.
                        We are fairly confident we could have easily made 600+ with a few more pounds of boost.
                        The plan for this winter is bigger exhaust and a custom turbo, coupled with a custom intake manifold which I will build.
                        We will likely get booted from the track next year on drag radials.
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          It looks like a Supra, not a 3000GT Alien...
                            Oops. What Nate said.
                              funky_monkey58
                              Interesting discovery. Hooked up my laptop finally and did some pulls with the same settings we had at the track and the most boost our EBC would give us was 19psi with one spike at 20psi.
                              So this car definitely has more in it. And I started playing with the two step just a bit kinda neat having 16psi in neutral.
                                aliengotpsi
                                Nate I saw that after i posted that but didnt care to edit..
                                Is this the guy who was at the MAP event in BIR? If so I remember Tufte ripping in to you... might be a different guy.. O and more than likely DB converts to Dyno Jet numbers..
                                Kevin Smith
                                  funky_monkey58
                                  Yup that was me. And to this day I will stand by my point, that at work we do build our own turbos. And just because we use garretts wheels does not take that away. That is like saying Tufte doesn't make his own manifolds because he doesn't have a mandrel bender and roll his own stainless tubing.
                                    aliengotpsi
                                    I was to drunk to remember what u were bitchn about..
                                    Kevin Smith
                                      Oh shit, that was you.....haha, yea, you made your self look like an idiot.........never connected that you were him. You said a lot more than that you just used garret wheels....
                                        funky_monkey58
                                        http://www.suprasport.com/gallery.asp?catalogid=756
                                        They look pretty good for a bs turbo huh?
                                        • C Offline
                                          C Offline
                                          Cobra Rob
                                          what a quick ride good job man:icon_salut:
