  3. Track Talk
  4. Well we finally went to the track with the blue car.
24 Posts 10 Posters 3.8k Views
    Tire spinnin mofo im figuring.
      still....
      is that thing a tank or what?
        yeah its like 3600lbs or so. Trust me it has more in it than that, when we were out driving around in it, i can say it would have given my TA a run
        • funky_monkey58F Offline
          funky_monkey58
          Just wait until next year should be even more fun with a bigger turbo, and a custom intake manifold.
            aliengotpsi
            thats an easy 11 car as is.. 2.0 60 foot is really bad.. id say its close to a 11.5-11.6 car with a 1.7 60 foot.
            does it make 550 hp on a DD dyno converted to Dynojet numbers? if not thats close to 640 hp.. on a Dynojet.. How much boost are you running.? What fuel? What turbos
            IF you want we can do a roll on against my EVO which has ran a shitty best of 11.3@ 126 1.7 60 foots made 535hp 470 TQ on 30 psi w/ E85
            Kevin Smith
            Straightlinedetailing.com
              funky_monkey58
              GT3582R turbo A1000 fuel pump with a sumped tank, -8 feed line -6 return, 1200cc injectors, E85. Tuned on Shanes dyno at DB. So it was on a dynodynamics at 22psi.
              We are fairly confident we could have easily made 600+ with a few more pounds of boost.
              The plan for this winter is bigger exhaust and a custom turbo, coupled with a custom intake manifold which I will build.
              We will likely get booted from the track next year on drag radials.
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                It looks like a Supra, not a 3000GT Alien...
                  Oops. What Nate said.
                    funky_monkey58
                    Interesting discovery. Hooked up my laptop finally and did some pulls with the same settings we had at the track and the most boost our EBC would give us was 19psi with one spike at 20psi.
                    So this car definitely has more in it. And I started playing with the two step just a bit kinda neat having 16psi in neutral.
                      aliengotpsi
                      Nate I saw that after i posted that but didnt care to edit..
                      Is this the guy who was at the MAP event in BIR? If so I remember Tufte ripping in to you... might be a different guy.. O and more than likely DB converts to Dyno Jet numbers..
                      Kevin Smith
                        funky_monkey58
                        Yup that was me. And to this day I will stand by my point, that at work we do build our own turbos. And just because we use garretts wheels does not take that away. That is like saying Tufte doesn't make his own manifolds because he doesn't have a mandrel bender and roll his own stainless tubing.
                          aliengotpsi
                          I was to drunk to remember what u were bitchn about..
                          Kevin Smith
                            Oh shit, that was you.....haha, yea, you made your self look like an idiot.........never connected that you were him. You said a lot more than that you just used garret wheels....
                              funky_monkey58
                              http://www.suprasport.com/gallery.asp?catalogid=756
                              They look pretty good for a bs turbo huh?
                              • C Offline
                                C Offline
                                Cobra Rob
                                what a quick ride good job man:icon_salut:
                                  So do ebay turbos......
                                  You were saying a lot more shit than that, like that you should select the engine around what turbo you wanted to run, that you could get turbos from china and change the housings to sell for a lot more, and some other things. Now maybe you were just really drunk, but you sounded pretty stupid.
                                  Do you make your own center sections and just use garret wheels?? Or do you just make housings??
                                    funky_monkey58
                                    I was pretty drunk, I would never support selling anything china brand, as a house product.
                                    The castings are designed in house, and machined in house. We use Comp Turbo center sections, and work closely with Comp on new turbos.
                                    I must have been trying to make a point on efficiency of a turbo and if you have a turbo you are set on, it would be idle on certain engines and not all.
                                    I really don't know though I was pretty gone by then.
                                      Understandable, most of us were.
                                      • Chance91C Offline
                                        Chance91C Offline
                                        Chance91
                                        Pretty Damn slick car, man.
                                        Fairly obvious, but as said, you could probably pull a good 1/2 second or better out of the car as it sits with better tires and smaller/wider wheels (probably smaller/ lighter, more so) Were you running the Dirreza star specs? Pretty decent road rubber.
                                        Any plans for some suspension mods (is it like, 20yr old stock supsension? or aftermarket, uprated, etc?) for a bit better weight transfer?
                                        Very clean as well, anyway. Sweet supra.
