  3. Run Your Mouth
  4. MDGFAB can not deliver AGAIN!!!!
271 Posts 54 Posters 28.1k Views
  • drift86D
    drift86D
    drift86
    And why is that?
    AE86 project: sold
    93 r33 gts25t new project
    00 impreza obs
    • ParkerP
      ParkerP
      because Will is setting you up, is my guess.....
      BlueSRT0483;244555 wrote:
      Trafik Jamz;260984 wrote:
      You are right Parker.
      • drift86D
        drift86D
        drift86
        O ok well I have seen some of his work and it is pretty good
        AE86 project: sold
        00 impreza obs
        • DelSlowD
          DelSlowD
          I dunno, looked to me as if 1/2 the welds were missing on the bottom half of the cage. I'm not sure if it is designed that way, but I couldn't see how a 'half moon' type weld would be structurally sound on the base of a cage...but then again, could be the way it's suppose to.
          • wesholeW
            wesholeW
            Or it could be that he wasnt finished welding it in yet. Just a thought. I personally have no clue.
            • DelSlowD
              DelSlowD
              Well it was all spray painted chrome, so I am assuming since he painted it..it was 'done.'
              • PSiedTSiP
                PSiedTSiP
                I can't remember off the top of my head for sure, but I think NHRA only requires a certain amount of area welded? I could be wrong, but I'm pretty sure its something like that...
                spanish-rice;237125 wrote:
                • DelSlowD
                  DelSlowD
                  ya it was like the welds went about half way around the tube, then just nothing. So like only half of it was welded.
                  • zbrownZ
                    zbrownZ
                    for roll bars anyway
                    "4:10 ROLL BARS
                    Mandatory in all cars running 11.49 or quicker, or per Class
                    Requirements. All roll bars must be within 6 inches of the rear
                    or side of the driver’s head, extend in height at least 3 inches
                    above the driver’s helmet with driver in normal driving position,
                    and be at least as wide as the driver’s shoulders or within 1
                    inch of the driver’s door. Roll bar must be adequately supported
                    or cross-braced to prevent forward or lateral collapse. Rear
                    braces must be of the same diameter and wall thickness as the
                    roll bar and intersect with the roll bar at a point not more than 5
                    inches from the top of the roll bar. Crossbar and rear braces
                    must be welded to main hoop. Sidebar must be included on
                    driver’s side and must pass the driver at a point midway
                    between the shoulder and elbow. Swing-out sidebar permitted.
                    All roll bars must have in their construction a cross bar for seat
                    bracing and as the shoulder-harness attachment point; cross
                    bar must be installed no more than 4 inches below, and not
                    above, the driver’s shoulders or to side bar. All vehicles with
                    OEM frame (i.e., pickup truck where body bolts to framerails)
                    must have roll bar welded or bolted to frame. Installation offrame connectors on unibody cars does not constitute a frame;
                    therefore, it is not necessary to have the roll bar attached to the
                    frame. Unibody cars with stock floor and firewall (wheeltubs
                    permitted) may attach roll bar with 6-inch x 6-inch x .125-inch
                    steel plates on top and bottom of floor bolted together with at
                    least four 3/8-inch bolts and nuts, or weld main hoop to rocker
                    sill area with .125-inch reinforcing plates, with plates welded
                    completely. All 4130 chrome moly tube welding must be done by
                    approved TIG heliarc process; mild steel welding must be done
                    by approved MIG wire feed or approved TIG heliarc process.
                    Welding must be free of slag and porosity. Any grinding of
                    welds prohibited. See illustration. Roll bar must be padded
                    anywhere driver’s helmet may contact it while in driving
                    position. Adequate padding must have minimum 1/4-inch
                    compression or meet SFI Spec 45.1."
                    • DelSlowD
                      DelSlowD
                      "4:10 ROLL BARS
                      completely
                      Ok so definitely not legal.
                      • drift86D
                        drift86D
                        drift86
                        Plates welded completely yes! Also remember this is a drift car not a drag car go to formulaD.com for there regulations
                        AE86 project: sold
                        00 impreza obs
                        • DelSlowD
                          DelSlowD
                          Very true, what are the rules on that for a drift event?
                          • drift86D
                            drift86D
                            drift86
                            For just your normal drift event it is just a minnimum 4 point with door bars to tandem but a formulaD event I am not possitive I have the rule book at home ill have to check and will post copy of what it says. But as for any plan drift event he is legal
                            AE86 project: sold
                            00 impreza obs
                            • RexwagonR
                              RexwagonR
                              Party in here
                              • X
                                X
                                Xracer
                                I did the cage back in the day when my car looked like this...
                                I was 17 or so at the time. First cage I ever made, shitty welder, didn't know enough about what I was doing. It was made to pass Club FR Drift Day specs for tandem runs. It passes tech there, but would not pass FD tech due to the two missing weld spots. I can simply finish the weld on the two rear down tubes and it would pass FD tech. Regardless, the whole cage sucks as far as fit and finish, not going to argue with that. It stiffened up the chassis like crazy though.
                                • RexwagonR
                                  RexwagonR
                                  so whats your opinion on this thread
                                  • X
                                    X
                                    Xracer
                                    I'll make my statements when this job is complete. He said i'd have it by tomorrow (well today really since its 2am now) so we'll see what happens.
                                    • X
                                      X
                                      Xracer
                                      And for those who are curious, you can see some progress of the car here: http://www.d-town.us/forum/viewtopic.php?t=4669
                                      • T
                                        T
                                        Trafik Jamz
                                        Huh? You're never gonna fit in around here being all nice and stuff....
                                        In all seriousness, thanks for not adding to the drama and for giving Matt a chance to redeem himself in your eyes. Everything Matt has ever done for me turned out nice (and on time) so I don't think quality will be the deciding factor.
                                        701.541.3484
                                        • gsrEKG
                                          gsrEKG
                                          gsrEK
                                          and i am in the same boat as you. i have had 2 turbo setups by matt and i coulden't be any happier. and has completed then in a timely manner.
                                          2009 Yamaha Zuma 125, gas HOG
                                          2008 Honda Fit daily
                                          A s2k
                                          1991 Honda civic DX Mint SOLD
                                          1988 Mitsubishi Mighty max
                                          BlackEJ8;233529 wrote:
