  4. Car Updates / Progress
  5. Finally Done...
Finally Done...
57 Posts 24 Posters 9.4k Views
  • wishinskyW Offline
    wishinskyW Offline
    wishinsky
    Very nice, looks clean. Now to go have some fun with the new boost!
    -Cars i drive
    2002 Mustang
    1997 Bravada Smart Track
    • Toys
      05 TTR 125 L/LE
      02 YZ 85 with 110cc kit
    • 63vette6 Offline
      63vette6 Offline
      63vette
      Why didnt you just buy a 180 bend, cut it, trim it, rotate it and weld it once instead of 11 pie cuts? I have 3, 3.5 and 4 in ss sitting in the garage. It may be a good idea to grind all that sugar out of the tube before it breaks off. Other than that good job.
      This pic is going to end up on a fail poster.
        Oh I dunno...bend radius?
          aliengotpsi
          That pie cut down pipe is for JDM POINT'S duh!!
          Kevin Smith
          Straightlinedetailing.com
            Trafik Jamz
            shoulda used tittymania....err...titanium for mad jdm props though
            701.541.3484
            • Chance91C Offline
              Chance91C Offline
              Chance91
              Is that Sch. 40? It looks thick enough to be...
              Either way, like everyone else, I'd be worried about those welds holding up in the long run... lot of potential for failure there.
              The manifold is pretty damn nice, who made it, or where'd it come from? Don't see those "T"s used too often, love the minimum number of welds that requires.
              So, is that 33.33 per wheel?
              Whats it make to the rears?
                .......lol
                  Ok for one that is a 2.5" dp, and i can tell you have never worked in a confined space. the "pie" cuts allow for an infinite bend radius. pretty much what ever i feel is needed. there is no other way to accomplish what we had to do here using a mandrel bend. plain and simple.
                  also how would "suger" break off in the downpipe effect anything at all? it's in the downpipe.
                  Now onto you saying that was fail. I'm all ears to how you would build that downpipe with the same radius using a u bend. not going to happen again.
                    well I'm not to worried about it, there is very minimal stress on the downpipe unless your banging it off the ground (will :icon_shaking:)....
                    The manifold is sch 10 but the T's come with the straight section out of sch 40 for some reason.
                      aliengotpsi
                      Why is that flange so fat? 1''?
                      Kevin Smith
                      • 63vette6 Offline
                        63vette6 Offline
                        63vette
                        Yeah right. I dont know shit about building cars. I will put a grand that says I can make a better downtube for that car than your 11 pie cut pile of junk. Put your money where your pie cut hole is.
                        • Chance91C Offline
                          Chance91C Offline
                          Chance91
                          That is odd. Great looking Mani, and it'll be around for the long haul it sounds like.
                          Still, that downpipe section gives me the willies. Seen a few cracked welds before on Miata's, though, there isn't a ton of stress on it like you said, from the looks of it. different story with our setup..
                            aliengotpsi;288529 wrote:
                            why is that flange so fat? 1''?
                            internal wastegate
                              thanks for the sig
                              • 63vette6 Offline
                                63vette6 Offline
                                63vette
                                No problem
                                  Well, i was having these made at a machine shop and i had talked with him about making them out of 3/4" and making a pocket for the internal flaper to have plenty of flow.
                                  After making the first one they will flow tons, but there just a little thick. so i will be cutting them down slightly.
                                    So then do it. You have no clue the space constraints yet think you will make one with a fucking u -bend. Get your head out of your ass and realize that you can't buy 2.5" u-bends with a fucking 1.5",1.75", 2" CLR.
                                    I don't do pie cuts because there "JDM" i do them when there is no bend that will fit given the CLR.
                                    I'm not going to argue with you over a downpipe. so drop it.
                                    • L Offline
                                      L Offline
                                      Link
                                      Banned
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        DrifterExtreme;288549 wrote:
                                        So then do it. You have no clue the space constraints, yet think you will make one with a fucking u -bend. Get your head out of your ass and realize that you can't buy 2.5" u-bends with a fucking 1.5",1.75", 2" CLR.
                                        I am assuming the bet was accepted, so who is going to hold the money?
                                        • 63vette6 Offline
                                          63vette6 Offline
                                          63vette
                                          If Delslow will allow me to fix it then Bill will have my thousand on Monday.
