  2. Local Shops and Businesses
  3. Straightline Detailing
  4. Headlight Reconditioning
27 Posts 9 Posters 2.6k Views
  • A
    A
    aliengotpsi
    2000 Ford Taurus 92,125 Miles
    Dealer Car
    Kevin Smith
    Straightlinedetailing.com
    • A
      A
      aliengotpsi
      Passenger Side
      Kevin Smith
      • DrifterExtremeD
        DrifterExtremeD
        Wow great job. how much you charge for this?
        • JoelJ
          JoelJ
          good plan switching to air powered tools kevin :thumbs up:
          • A
            A
            aliengotpsi
            Yeah we have switched over to air after doing up to 40 sets a month..
            We usually charge $50.00 (dealer price) We don't advertise it so we don't get many retail clients wanting this.
            $60.00 retail
            That set was not very bad but you get the idea..
            Kevin Smith
            • DrifterExtremeD
              DrifterExtremeD
              Well i have a set of lights i need done, there not bad at all, but i want them blingin. haha
              • amichezeA
                amichezeA
                I was actually just wondering about getting that done a couple days ago.
                Fargostreet Trolls wrote:
                i must be stupid
                • wesholeW
                  wesholeW
                  Looks like the same kit we use here Kevin. Shit works awesome.
                  • A
                    A
                    aliengotpsi
                    Wes its, sand paper, Air DA sander, Dewalt buffer, mini polisher, UV clear coat..
                    How much do you charge ? How many do you guys do?
                    Kevin Smith
                    • svxALS
                      svxALS
                      svxAL
                      do you 1500 then 3 or do u cut a little deeper seem to do alot of these at school
                      94 Subaru SVX FWD
                      subaru-svx.net
                      1999 silverado
                      • A
                        A
                        aliengotpsi
                        Most cars get sanded W/
                        240
                        400
                        600
                        1000
                        1500
                        Then buffed
                        Cleared w/ uv clear
                        Kevin Smith
                        • wesholeW
                          wesholeW
                          Here's the kit we use.
                          http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Featured_Products/Headlight/
                          We charge $50/pair to do the job. Unfortunately, we have not been doing the u/v clear afterward. That is something we have not had the resources to get ahold of. Is what you use in aerosol can or applied using a gun?
                          • svxALS
                            svxALS
                            svxAL
                            [QUOTE=aliengotpsi;293832]Most cars get sanded W/
                            240
                            400
                            600
                            1000
                            1500
                            Then buffed
                            Cleared w/ uv clear[/QUOTE
                            really 240 lol holy shit ive took headlights out of the junkyard and 1000 was the most coarse I got and they looked brand new i mean they were bad you couldn't even see inside to the reflector. dont you think its a little over board to do clear or does it just help so they dont get crapped up within the next couple years
                            94 Subaru SVX FWD
                            subaru-svx.net
                            1999 silverado
                            • bubbaB
                              bubbaB
                              240
                              400
                              600
                              1000
                              1500
                              Then buffed
                              this is what i was thinking too...
                              • A
                                A
                                aliengotpsi
                                240
                                400
                                600
                                1000
                                1500
                                Then buffed
                                Would you buff and polish a car and not protect it? What you are doing when you sand the headlights you are removing a OEM coating that had been broken down by the UV- Rays/Bugs/etc.
                                On some car 240 is over board but then if you have some like cadillacs they have a much harder coating on the headlight and takes longer using higher than 240.
                                The coating we have been currently using is a wipe on on. but others we have are spray on and have to be cured with a UV LIGHT.
                                Kevin Smith
                                • A
                                  A
                                  aliengotpsi
                                  Wes thats a good kit.. You may want to jump up to a full size buffer to make polishing out the sanding marks faster and use the small DA polisher for the hard to reach areas..
                                  Kevin Smith
                                  • wesholeW
                                    wesholeW
                                    What clear are you using Kevin?
                                    • svxALS
                                      svxALS
                                      svxAL
                                      aliengotpsi;293868 wrote:
                                      [quote=svxAL;293850]
                                      Would you buff and polish a car and not protect it?.
                                      i geuss im confused at this ussaully after i pull a car outta the booth i cut it then buff it then polish then run it out the door thats how i was taught and how most body shops do it :icon_scratch:
                                      94 Subaru SVX FWD
                                      subaru-svx.net
                                      1999 silverado
                                      • A
                                        A
                                        aliengotpsi
                                        svxAL;293871 wrote:
                                        [quote=aliengotpsi;293868]
                                        After you polish a car you need to wax or seal it , unless its fresh paint. But I do love fixing body shop buff jobs... Newbs Leaving swirls, holograms,fish-tails, sanding marks, compund in the cracks... If you work at a body shop you should know what I mean. Very few do a decent job. im sure the reason is that it may take days to wet sand and buff , polish to make a car perfect..
                                        Kevin Smith
                                        • svxALS
                                          svxALS
                                          svxAL
                                          aliengotpsi;293872 wrote:
                                          [quote=svxAL;293871]
                                          well i guess ive only done freshly painted vehicles and a few scratches on friends cars. and well I geuss I wet sanded with 3000 my whole car the buffed and polished it and it looks really good took out almost all imperfections. and as for the compound getting all over that's what the detail/recon place is for cleaning the vehicle we fix. It then goes to them to clean and make it look good. And as for swirls and some LITTLE sanding marks/dull spots sometimes u miss them when u have half a car that needs to be cutt buffed, polished and throw back together than to recon to be detailed and back to the owner that day lol.
                                          94 Subaru SVX FWD
                                          subaru-svx.net
                                          1999 silverado
