  4. 700whp 1990 Civic Wagon
59 Posts 18 Posters 9.9k Views
  • C Offline
    C Offline
    Cobra Rob
    Is this for real?
    http://videos.streetfire.net/video/Wicked-Wagovan_725859.htm
      is snow for real?
        Is Santa for real?
        • C Offline
          C Offline
          Cobra Rob
          are you guys for real
            lawl Bisomoto...
            • s13coupeS Offline
              s13coupeS Offline
              s13coupe
              weshole;296919 wrote:
              Is Santa for real?
              For sure.
              '87 300zx Turbo - summer car
              '90 300zx RB25 - drift car
              '95 Civic sedan - hooptie
                Cobra Rob;296914 wrote:
                Is this for real?
                yes it is... so is his 450hp F22 non-vtec NA in an Insight that runs mid 9's
                • BassplayerB Offline
                  BassplayerB Offline
                  Bassplayer
                  I want this
                  1995 GMC Sierra
                    Oh it probably makes 700hp but it sure as fuck doesn't on pump 91 with meth like he claims it does.
                      Are you for real?
                        KA-T_240;296986 wrote:
                        Are you for real?
                        Do you know anything?
                        • Bp-08B Offline
                          Bp-08B Offline
                          Bp-08
                          I bet its very streetable also like they are saying.
                            Are you for real?
                            http://videos.streetfire.net/video/Bisimoto-700whp-D16Z-1990_725859.htm
                            Watch the video yourself.
                            This guy is a con artist and sounds like a used car salesman.
                                do you know anything will??
                                How would that be any less streetable than all the 400-500 Whp hondas running around? It has exhaust, interior, etc, and toucan turn the boost down. Yeah bisi is a salesman, if you don't like it, don't buy from him. You haters make me LOL.
                                  For one it is going to need a turbo that will support 700whp..... and that turbo is not going to be as streetable as a turbo that will support 400-500whp... especially on a honda
                                    Really you beleave 700whp pump 91 w/meth? You should know better then that.
                                    He said it made what 300 whp on 1 bar (14-15lbs ish). So this is running what 30+ lbs to get to "700whp". I'm to beleave a small bore, small displacment, small port, 9:1 comp D series is to make 20ish hp per psi above his 300whp/1bar statment.
                                    Have you seen his short dyno pull at LOW boost?
                                    [ame]http://www.youtube.com/watch?v=FIhA7_c_Yx0&feature=player_embedded[/ame]
                                    In my opinion you don't get runners glowing that hot that fast unless your running low timing, Correct?
                                    So would only lead me to question what would happen at a higher boost level like 30psi+ psi. Correct?
                                    So how am i a hater and in any way funny? If he would have said were going for 700whp and never mentioned pump 91 there would be no issue. Done deal.
                                      BassplayerB Offline
                                      Bassplayer
                                      I guess he's doing it to try to win an engine building competition, power numbers seem to be legit to me if you believe what he says. Here's the Honda-Tech article that Bisimoto wrote about his project, check it: http://honda-tech.com/showthread.php?t=2679300&highlight=700whp
                                      1995 GMC Sierra
                                        No Zac, no matt...gosh you guys know nothing.
                                        • thurmanmermanT Offline
                                          thurmanmerman
                                          lol
                                          > Parker;299126 wrote:
