  4. 700whp 1990 Civic Wagon
59 Posts 18 Posters 9.9k Views
  • RexwagonR
    RexwagonR
    is snow for real?
    • wesholeW
      wesholeW
      Is Santa for real?
      • C
        C
        Cobra Rob
        are you guys for real
        • DelSlowD
          DelSlowD
          lawl Bisomoto...
          • s13coupeS
            s13coupeS
            s13coupe
            weshole;296919 wrote:
            Is Santa for real?
            For sure.
            '87 300zx Turbo - summer car
            '90 300zx RB25 - drift car
            '95 Civic sedan - hooptie
            • bubbaB
              bubbaB
              Cobra Rob;296914 wrote:
              Is this for real?
              http://videos.streetfire.net/video/Wicked-Wagovan_725859.htm
              yes it is... so is his 450hp F22 non-vtec NA in an Insight that runs mid 9's
              • BassplayerB
                BassplayerB
                Bassplayer
                I want this
                1995 GMC Sierra
                • DrifterExtremeD
                  DrifterExtremeD
                  Oh it probably makes 700hp but it sure as fuck doesn't on pump 91 with meth like he claims it does.
                  • K
                    K
                    Are you for real?
                    • DelSlowD
                      DelSlowD
                      KA-T_240;296986 wrote:
                      Are you for real?
                      Do you know anything?
                      • Bp-08B
                        Bp-08B
                        Bp-08
                        I bet its very streetable also like they are saying.
                        • DrifterExtremeD
                          DrifterExtremeD
                          Are you for real?
                          http://videos.streetfire.net/video/Bisimoto-700whp-D16Z-1990_725859.htm
                          Watch the video yourself.
                          This guy is a con artist and sounds like a used car salesman.
                          • inspector01I
                            inspector01I
                            • inspector01I
                              inspector01I
                              do you know anything will??
                              How would that be any less streetable than all the 400-500 Whp hondas running around? It has exhaust, interior, etc, and toucan turn the boost down. Yeah bisi is a salesman, if you don't like it, don't buy from him. You haters make me LOL.
                              • zbrownZ
                                zbrownZ
                                For one it is going to need a turbo that will support 700whp..... and that turbo is not going to be as streetable as a turbo that will support 400-500whp... especially on a honda
                                • DrifterExtremeD
                                  DrifterExtremeD
                                  Really you beleave 700whp pump 91 w/meth? You should know better then that.
                                  He said it made what 300 whp on 1 bar (14-15lbs ish). So this is running what 30+ lbs to get to "700whp". I'm to beleave a small bore, small displacment, small port, 9:1 comp D series is to make 20ish hp per psi above his 300whp/1bar statment.
                                  Have you seen his short dyno pull at LOW boost?
                                  [ame]http://www.youtube.com/watch?v=FIhA7_c_Yx0&feature=player_embedded[/ame]
                                  In my opinion you don't get runners glowing that hot that fast unless your running low timing, Correct?
                                  So would only lead me to question what would happen at a higher boost level like 30psi+ psi. Correct?
                                  So how am i a hater and in any way funny? If he would have said were going for 700whp and never mentioned pump 91 there would be no issue. Done deal.
                                  • BassplayerB
                                    BassplayerB
                                    Bassplayer
                                    I guess he's doing it to try to win an engine building competition, power numbers seem to be legit to me if you believe what he says. Here's the Honda-Tech article that Bisimoto wrote about his project, check it: http://honda-tech.com/showthread.php?t=2679300&highlight=700whp
                                    1995 GMC Sierra
                                    • DelSlowD
                                      DelSlowD
                                      No Zac, no matt...gosh you guys know nothing.
                                      • thurmanmermanT
                                        thurmanmermanT
                                        thurmanmerman
                                        lol
                                        Parker;299126 wrote:
                                        blah blah blah blah blah blah blah blah blah blah blah blah German cars are the best thing since sliced bread.
                                        • inspector01I
                                          inspector01I
                                          Well that is obvious, to get to these levels it is a necessity, but I meant it would have no issues being driven anywhere, although response won't be great.
                                          Matt, no one believed he could go 10s with an N/A D15, or mid 9's at ~150 with an N/A F22, but he has done both. I would say that making ~350 hp on an N/A F22 would be just as hard as this projects goals, but he did that and it is proven with outside testing. Therefore, I am not saying he has/will make his goal, but Im also not willing to say it isn't possible. I agree that it is a very lofty and improbably goal, but he has done things many times that people said wasn't possible, so Im not ready to dismiss it either.
                                          I haven't been watching this project too closely, but I did see that vid and I believe somewhere that bisi said he was running pretty low timing.
                                          You are a hater because you are dismissing it is a possibility before seeing any results or having anything to even compare it against. Do you have any comparisons of a honda motor going for big power with pump/meth? I never see anyone try this with hondas. People have said it wasn't possible for many of bisi's projects but so far he has proven them wrong so Im giving him the benefit of the doubt for right now, and saying he may possibly do it.
