  4. Ticket for Yellow Headlights
45 Posts 23 Posters 6.8k Views
  • smtomps1955S
    smtomps1955S
    smtomps1955
    Then what about the cars with factory hids? its almost like a double negative hids are illegal, but if there factory equipped that makes it ok??
    2003 f150 supercrew
    2002 Urabus WRX sedan
    1991 Nissan Hardbody
    :icon_puke_l:
    • JoelJ
      JoelJ
      If the Vehicle has properly designed housings, then HID's are not blinding to oncoming traffic. Throwing a set of Drop in HID kits into stock headlight housings made for halogens doesnt give you a cut off, and is super annoying. Even Projector housing headlights that are designed for Halogens kill your eyes when driving(Shanes G5). Plus, Most laws don't apply to any OEM equiptment, its somewher eon the MN site, I just can't find it again.
      • MisterCMKM
        MisterCMKM
        Joel, check out this section. 169.55 requires that your headlights project a white light. Now the argument is what one considers to be white light.
        169.55 LIGHTS ON ALL VEHICLES.
        Subdivision 1. Lights or reflectors required. At the times when lighted lamps on vehicles
        are required each vehicle including an animal-drawn vehicle and any vehicle specifically
        excepted in sections 169.47 to 169.79, with respect to equipment and not hereinbefore specifically
        required to be equipped with lamps, shall be equipped with one or more lighted lamps or lanterns
        projecting a white light visible from a distance of 500 feet to the front of the vehicle and with a
        lamp or lantern exhibiting a red light visible from a distance of 500 feet to the rear, except that
        reflectors meeting the maximum requirements of this chapter may be used in lieu of the lights
        required in this subdivision. It shall be unlawful except as otherwise provided in this subdivision,
        to project a white light to the rear of any such vehicle while traveling on any street or highway,
        unless such vehicle is moving in reverse. A lighting device mounted on top of a vehicle engaged
        in deliveries to residences may project a white light to the rear if the sign projects one or more
        additional colors to the rear. An authorized emergency vehicle may display an oscillating,
        alternating, or rotating white light used in connection with an oscillating, alternating, or rotating
        red light when responding to emergency calls.
        Subd. 2. Implement of husbandry. (a) At the times when lighted lamps on vehicles are
        required:
        (1) every self-propelled implement of husbandry must be equipped with at least one lamp
        displaying a white light to the front, and at least one lamp displaying a red light to the rear;
        (2) every self-propelled implement of husbandry must also display two red reflectors visible
        to the rear;
        (3) every combination of a self-propelled and towed implement of husbandry must be
        equipped with at least one lamp mounted to indicate as nearly as practicable the extreme left
        projection of the combination and displaying a white or amber light to the front and a red or amber
        light to the rear of the self-propelled implement of husbandry; and
        (4) the last unit of every combination of implements of husbandry must display two red
        reflectors visible to the rear.
        (b) The reflectors must be of the type approved for use upon commercial vehicles. The
        reflectors must be mounted as close as practicable to the extreme edges of the implement of
        husbandry. The reflectors must be reflex reflectors that are visible at night from all distances
        within 600 feet to 100 feet when directly in front of lawful lower beams of headlamps.
        Subd. 3. Implement of husbandry; hazard warning lights. No person may operate a
        self-propelled implement of husbandry manufactured after January 1, 1970, on a highway
        unless the implement of husbandry displays vehicular hazard warning lights visible to the front
        and rear in normal sunlight.
        History: (2720-241) 1937 c 464 s 91; 1947 c 428 s 27; 1949 c 574; 1959 c 410 s 1; 1979 c
        185 s 2; 1981 c 44 s 1; 1993 c 187 s 7,8; 1999 c 238 art 2 s 21,93; 2000 c 479 art 1 s 12
        169.56 AUXILIARY LIGHTS.
        Subdivision 1. Spotlight. Any motor vehicle may be equipped with not to exceed two spot
        lamps and every lighted spot lamp shall be so aimed and used upon approaching another vehicle
        that no part of the high-intensity portion of the beam will be directed on the road surface to the
        left of the center of the vehicle, nor more than 100 feet ahead of the vehicle upon which such
        lamps are mounted.
        Subd. 2. Fog light. Any motor vehicle may be equipped with not to exceed two fog lamps
        mounted on the front at a height not less than 12 inches nor more than 30 inches above the level
        surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of
        the high-intensity portion of the light to the left of the center of the vehicle shall at a distance of
        25 feet ahead project higher than a level of four inches below the level of the center of the lamp
        from which it comes. Lighted fog lamps meeting the above requirements may be used with lower
        headlamp beams as specified in section 169.60.
        Subd. 3. Auxiliary low-beam light. Except as provided in subdivision 5, any motor vehicle
        may be equipped with not to exceed two auxiliary low-beam lamps mounted on the front at a
        height of not less than 24 inches nor more than 42 inches above the level surface upon which the
        vehicle stands. The provisions of section 169.60 shall apply to any combination of headlamps and
        auxiliary low-beam lamps.
        Subd. 4. Auxiliary driving light. Except as provided in subdivision 5, any motor vehicle
        may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a
        height not less than 16 inches nor more than 42 inches above the level surface upon which the
        and auxiliary driving lamps.
        Subd. 5. Exception for light obstructed by snowplow blade. (a) The auxiliary lamps
        permitted in subdivision 3 may be mounted more than 42 inches high on any truck equipped with
        a snowplow blade that obstructs the required headlights. The lights may not be illuminated when
        a snowplow blade is not mounted on the vehicle.
        (b) No other vehicle may be operated on a public highway unless the auxiliary lamps
        permitted in subdivisions 3 and 4 comply with the height requirements or are completely covered
        with an opaque material.
        History: (2720-242) 1937 c 464 s 92; 1945 c 207 s 2; 1959 c 521 s 5; 1993 c 26 s 5-7;
        1994 c 600 s 4
        thrash;315544 wrote:
        Ford is back :)
        • T
          T
          Trafik Jamz
          After reading what Chris just posted, I think you are screwed Joel....I'd still fight it though.
          701.541.3484
          • JimJ
            JimJ
            How much is the ticket? I think you might be fucked, but if you go to traffic court maybe you can get dropped to a warning if you take the bulbs out?
            • StangerBanger96S
              StangerBanger96S
              StangerBanger96
              Joel;297274 wrote:
              I know what DOT is. What asked "What is DOT approved" I meant Which light is DOT Approved? Minnesota doesnt give out fix it tickets. they are just Tickets... Expensive ones.
              So when I did one of my ride a longs and the cop gave a girl a fix it ticket for her tail light...what was it? It wasn't from the same ticket book that he gave other violators tickets...
              • MisterCMKM
                MisterCMKM
                Minnesota certainly does give out fix-it-tickets. My brother got one for the tint on his 98 Camaro. He had to go back once the tint was removed and have an officer take a look.
                Ford is back :)
                • GoodnbuzzdG
                  GoodnbuzzdG
                  Goodnbuzzd
                  Welp, that certainly makes the argument a lot tougher. I know as of about 5 years ago ND didn't have anything that specific in there laws for lighting like that. CMK is right, now it is all in what is perceived as "White light" by the judge...... hopefully you get a judge like i did. Good luck
                  • kylushK
                    kylushK
                    kylush
                    This, my best friend also got one for having "loud exhaust." Had to fix it and go back and have it looked over to see if it was acceptable according to them.
                    1998 Z28 Camaro
                    • MisterCMKM
                      MisterCMKM
                      Joel got his ticket in MN. ND does not apply here.
                      Ford is back :)
                      • nuckinfutsN
                        nuckinfutsN
                        nuckinfuts
                        I had the same thing happen to me about 2 years ago, went to court fought it and beat the ticket. Joel I think your best bet is to argue that the law is too vague and does not clearly state which lights are legal or illegal. Good luck man hope it works out for ya.
                        • ruthless351R
                          ruthless351R
                          ruthless351
                          Plead color blind...... 🙂
                          • ihaveaidsI
                            ihaveaidsI
                            ihaveaids
                            Get rid of your gay yellow lights /thread.
                            • GoodnbuzzdG
                              GoodnbuzzdG
                              Goodnbuzzd
                              I understand that, that would be the reason i worded it the way i did. I think he's gonna have a tough one.
                              • amichezeA
                                amichezeA
                                This.
                                Fargostreet Trolls wrote:
                                i must be stupid
                                • JoelJ
                                  JoelJ
                                  Didn't even have to go to court. I called and left a message for the City Attorney that deals with traffic tickets. SHe told me he's a newb and sh dismissed it.
