  4. Ticket for Yellow Headlights
45 Posts 23 Posters 6.8k Views
  • JoelJ
    JoelJ
    smtomps1955;297275 wrote:
    Then what about the cars with factory hids? its almost like a double negative hids are illegal, but if there factory equipped that makes it ok??
    If the Vehicle has properly designed housings, then HID's are not blinding to oncoming traffic. Throwing a set of Drop in HID kits into stock headlight housings made for halogens doesnt give you a cut off, and is super annoying. Even Projector housing headlights that are designed for Halogens kill your eyes when driving(Shanes G5). Plus, Most laws don't apply to any OEM equiptment, its somewher eon the MN site, I just can't find it again.
    • MisterCMKM
      MisterCMKM
      Joel, check out this section. 169.55 requires that your headlights project a white light. Now the argument is what one considers to be white light.
      169.55 LIGHTS ON ALL VEHICLES.
      Subdivision 1. Lights or reflectors required. At the times when lighted lamps on vehicles
      are required each vehicle including an animal-drawn vehicle and any vehicle specifically
      excepted in sections 169.47 to 169.79, with respect to equipment and not hereinbefore specifically
      required to be equipped with lamps, shall be equipped with one or more lighted lamps or lanterns
      projecting a white light visible from a distance of 500 feet to the front of the vehicle and with a
      lamp or lantern exhibiting a red light visible from a distance of 500 feet to the rear, except that
      reflectors meeting the maximum requirements of this chapter may be used in lieu of the lights
      required in this subdivision. It shall be unlawful except as otherwise provided in this subdivision,
      to project a white light to the rear of any such vehicle while traveling on any street or highway,
      unless such vehicle is moving in reverse. A lighting device mounted on top of a vehicle engaged
      in deliveries to residences may project a white light to the rear if the sign projects one or more
      additional colors to the rear. An authorized emergency vehicle may display an oscillating,
      alternating, or rotating white light used in connection with an oscillating, alternating, or rotating
      red light when responding to emergency calls.
      Subd. 2. Implement of husbandry. (a) At the times when lighted lamps on vehicles are
      required:
      (1) every self-propelled implement of husbandry must be equipped with at least one lamp
      displaying a white light to the front, and at least one lamp displaying a red light to the rear;
      (2) every self-propelled implement of husbandry must also display two red reflectors visible
      to the rear;
      (3) every combination of a self-propelled and towed implement of husbandry must be
      equipped with at least one lamp mounted to indicate as nearly as practicable the extreme left
      projection of the combination and displaying a white or amber light to the front and a red or amber
      light to the rear of the self-propelled implement of husbandry; and
      (4) the last unit of every combination of implements of husbandry must display two red
      reflectors visible to the rear.
      (b) The reflectors must be of the type approved for use upon commercial vehicles. The
      reflectors must be mounted as close as practicable to the extreme edges of the implement of
      husbandry. The reflectors must be reflex reflectors that are visible at night from all distances
      within 600 feet to 100 feet when directly in front of lawful lower beams of headlamps.
      Subd. 3. Implement of husbandry; hazard warning lights. No person may operate a
      self-propelled implement of husbandry manufactured after January 1, 1970, on a highway
      unless the implement of husbandry displays vehicular hazard warning lights visible to the front
      and rear in normal sunlight.
      History: (2720-241) 1937 c 464 s 91; 1947 c 428 s 27; 1949 c 574; 1959 c 410 s 1; 1979 c
      185 s 2; 1981 c 44 s 1; 1993 c 187 s 7,8; 1999 c 238 art 2 s 21,93; 2000 c 479 art 1 s 12
      169.56 AUXILIARY LIGHTS.
      Subdivision 1. Spotlight. Any motor vehicle may be equipped with not to exceed two spot
      lamps and every lighted spot lamp shall be so aimed and used upon approaching another vehicle
      that no part of the high-intensity portion of the beam will be directed on the road surface to the
      left of the center of the vehicle, nor more than 100 feet ahead of the vehicle upon which such
      lamps are mounted.
      Subd. 2. Fog light. Any motor vehicle may be equipped with not to exceed two fog lamps
      mounted on the front at a height not less than 12 inches nor more than 30 inches above the level
      surface upon which the vehicle stands and so aimed that when the vehicle is not loaded none of
      the high-intensity portion of the light to the left of the center of the vehicle shall at a distance of
      25 feet ahead project higher than a level of four inches below the level of the center of the lamp
      from which it comes. Lighted fog lamps meeting the above requirements may be used with lower
      headlamp beams as specified in section 169.60.
      Subd. 3. Auxiliary low-beam light. Except as provided in subdivision 5, any motor vehicle
      may be equipped with not to exceed two auxiliary low-beam lamps mounted on the front at a
      height of not less than 24 inches nor more than 42 inches above the level surface upon which the
      vehicle stands. The provisions of section 169.60 shall apply to any combination of headlamps and
      auxiliary low-beam lamps.
      Subd. 4. Auxiliary driving light. Except as provided in subdivision 5, any motor vehicle
      may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a
      height not less than 16 inches nor more than 42 inches above the level surface upon which the
      and auxiliary driving lamps.
      Subd. 5. Exception for light obstructed by snowplow blade. (a) The auxiliary lamps
      permitted in subdivision 3 may be mounted more than 42 inches high on any truck equipped with
      a snowplow blade that obstructs the required headlights. The lights may not be illuminated when
      a snowplow blade is not mounted on the vehicle.
      (b) No other vehicle may be operated on a public highway unless the auxiliary lamps
      permitted in subdivisions 3 and 4 comply with the height requirements or are completely covered
      with an opaque material.
      History: (2720-242) 1937 c 464 s 92; 1945 c 207 s 2; 1959 c 521 s 5; 1993 c 26 s 5-7;
      1994 c 600 s 4
      thrash;315544 wrote:
      Ford is back :)
      • T
        T
        Trafik Jamz
        After reading what Chris just posted, I think you are screwed Joel....I'd still fight it though.
        701.541.3484
        • JimJ
          JimJ
          How much is the ticket? I think you might be fucked, but if you go to traffic court maybe you can get dropped to a warning if you take the bulbs out?
          • StangerBanger96S
            StangerBanger96S
            StangerBanger96
            Joel;297274 wrote:
            I know what DOT is. What asked "What is DOT approved" I meant Which light is DOT Approved? Minnesota doesnt give out fix it tickets. they are just Tickets... Expensive ones.
            So when I did one of my ride a longs and the cop gave a girl a fix it ticket for her tail light...what was it? It wasn't from the same ticket book that he gave other violators tickets...
            • MisterCMKM
              MisterCMKM
              Minnesota certainly does give out fix-it-tickets. My brother got one for the tint on his 98 Camaro. He had to go back once the tint was removed and have an officer take a look.
              Ford is back :)
              • GoodnbuzzdG
                GoodnbuzzdG
                Goodnbuzzd
                Welp, that certainly makes the argument a lot tougher. I know as of about 5 years ago ND didn't have anything that specific in there laws for lighting like that. CMK is right, now it is all in what is perceived as "White light" by the judge...... hopefully you get a judge like i did. Good luck
                • kylushK
                  kylushK
                  kylush
                  This, my best friend also got one for having "loud exhaust." Had to fix it and go back and have it looked over to see if it was acceptable according to them.
                  1998 Z28 Camaro
                  • MisterCMKM
                    MisterCMKM
                    Joel got his ticket in MN. ND does not apply here.
                    Ford is back :)
                    • nuckinfutsN
                      nuckinfutsN
                      nuckinfuts
                      I had the same thing happen to me about 2 years ago, went to court fought it and beat the ticket. Joel I think your best bet is to argue that the law is too vague and does not clearly state which lights are legal or illegal. Good luck man hope it works out for ya.
                      • ruthless351R
                        ruthless351R
                        ruthless351
                        Plead color blind...... 🙂
                        • ihaveaidsI
                          ihaveaidsI
                          ihaveaids
                          Get rid of your gay yellow lights /thread.
                          • GoodnbuzzdG
                            GoodnbuzzdG
                            Goodnbuzzd
                            I understand that, that would be the reason i worded it the way i did. I think he's gonna have a tough one.
                            • amichezeA
                              amichezeA
                              This.
                              Fargostreet Trolls wrote:
                              i must be stupid
                              • JoelJ
                                JoelJ
                                Didn't even have to go to court. I called and left a message for the City Attorney that deals with traffic tickets. SHe told me he's a newb and sh dismissed it.
