Dave, Matt, Bill
dynotune;297693 wrote:
gas or korn? ls1 intake or ls6? seen the fuel system thing done a whole buncha times, but why not boost reference it? 15 lbs on 370 in LS motor is a pile of power, 60s def wont cut it on korn with no boost reference... just my experience. The higher pressure you run on your pump, the faster it runs outta steam (exponentially) you probably know this, but fyi. If you are on gas, you wont get your fuel trims to settle on 60s at 65-70 base FP. If it is reference @ 58 it will work (50 psi @ idle) On E85 that set-up runs out about 560 (procharged, prob about 600+/- turbo)to the tire on a returnless. IIRC, that set-up is good for low 700s on gas.Thanks for the pointers Andy.
It will be run on e85 and this is on a ls3/l92 topend
maybe i will run a reference line right away then, what you say makes sense
Plan was to make what power i could support on the 60's and be able to go to a bigger injector like some high imp. 90's or more... but already have the rest of the system ready to support some more hp.
This thing is coming to you to get tuned so any ideas or criticisms are greatly appreciated on fuel and other aspects....
the combo is a 370", TC78 1.15, TH350, 3.23 solid rear 8.8
send me your vette regulator, i was just gonna order one but ill buy your old shit instead, and any of your old FI line.
You are gonna need injectors anyway and it will work fine running non referenced if you want, doubt you will ever take that car over 10psi anyway, it will be about undriveable. I ran my 65#ers out at 16psi on my buick on gas at 70psi base pressure and you know how fast that was, corn none of my fuel system would go over 12. You can get FIC high imp injectors (ball and seat, the good ones) as big as you want now so that wont be an issue -
Zack, before you get carried away, what torque converter are you running? Any mods to the th350?
zbrown;297697 wrote:
Thanks for the pointers Andy.It will be run on e85 and this is on a ls3/l92 topend
z31;297717 wrote:
Zack, before you get carried away, what torque converter are you running? Any mods to the th350?it just has a summit converter right now, It will allow me to see how this acts first so i know what kind of good stall i want once I see how the car acts
Th350 is nothing special... just good clutches and bands
that is no biggie, they are cheap, and i have Schmidt in dickinson... they know how to build the th350/400's and PG's right
best thing i did was get rid of that 4l60
It will be run on e85Where is the nearest e85 pump even at....dickinson??
zbrown;297757 wrote:
yeah should have been at the annual meeting....blender pump in bowman..... awesomeness
lmfao. new pump announced at the annual meeting. THAT is awesomeness.
15 miles to fuel up=gay
exactly its gay.....you will hate it.
zbrown;297884 wrote:
you drive 20 to fuel up??? -
