  4. finally more turbo for the diesel
44 Posts 13 Posters 4.3k Views
  • SheeranS Offline
    SheeranS Offline
    Sheeran
    yeah i would water/meth for high egts.....but this will work easily...you should make a thread for the diesel
      Dibs on the HX35?? 🙂
      • SheeranS Offline
        SheeranS Offline
        Sheeran
        also what PSI you looking to run with this and what was your pevious PSI with the HX35 previously mentioned
          For what, your bookshelf??
            Yup, exactly. Only ever a bookshelf.
            • beachbum_jonB Offline
              beachbum_jon
              Yawn...
              Ditch that for a s357 over a s475...unless that is you are planning on using this as a top turbo someday..:)
              -John Adams, 1735-1826-
                beachbum_jon
                Yawn...
                Unless you are planning on butting this over a s480 or something someday
                  MNMKIV;298580 wrote:
                  ever consider a water meth injection to help with the egt's a bit?
                  The turbo alone should give the relief i need on the EGT's
                  Not getting carried away on this thing, I just want make around that 500whp mark and be able to use most of that power when pulling while keeping EGT's manageable..
                  may need twins to do that successfully, but this will give an idea of if that is required
                  had a 35psi gauge forever and just knew that it burried that... finally got my 60psi gauge on and it runs right at 42psi...... stock truck that vintage is at ~18psi stock
                  The stock HX35 is not doing anything good there but being a blow torch and sending drive pressure through the roof.... the new turbo is gated at 40psi..... 45-50psi should clean what fuel i have available currently
                  stock HX35s do fairly well up to about 32psi and it is down hill steeply above that
                  beachbum_jon;298596 wrote:
                  Yawn...
                  yeah, this turbo over a 400 variant
                  If this cools what i want then no need to though
                  This isn't some drag racing toy.... I DD it and pull often, and like to have a beast when i am pulling 😉
                  What i really need to happen is for the stock HG to let go so that i have motive to pull the head and have that rebuilt, ported, and o-ringed with some studs
                  If i need more fuel the next thing i would do is delivery valves....... not going to some recockulous big injectors because i like my mileage and clean burn
                  i do around that 20mpg mark on I-state at 80 and a bit better at a slower speed
                  bumping my timing, the injectors, and taller tires helped in the mileage department
                    beachbum_jon
                    i nice set of tow twins would be a s357/s475
                      ooooo you will have to come visit my dad now! He will probably want to take a look under there!!
                        Have to see how this spools by itslef
                        Auto truck so once i get it spooled once i am good to go regardless
                        Manual trucks would blow balls trying to pull with a single this size......... every shift re-spooling without the converter to help you
                          beachbum_jon
                          yeah mu buddy had that same turbo you just got on his vp44 truck which is a 5spd and with stock injectors, monster stage 1 pump, he could barely spool that thing, then we built his twins and he got 150's and it moves pretty good.
                          • SheeranS Offline
                            SheeranS Offline
                            Sheeran
                            good luck with it....i almost hope it doesn't do what you want cuz i want to see a twin build....lol
                            How big is the Diesel truck scene around here i saw a Harlel Davidson eddition F-250 in diesel power a few months ago and i've seen a few nice trucks driving around (not to mention all the trucks at M-state when diesel tech classes are going on) but it doesn't seem to big
                              True story! I drove a 2006 Dodge 3500 Cummins(long box, 4 door, dually) in a 6-speed when I moved. I hated every second of it.
                              • 91nbtsi9 Offline
                                91nbtsi9 Offline
                                Zach, is your trans built?
                                  my pickup had fueling mods before i got it.....so i don't know if he did something to the stock tranny or not...
                                  but somehow it shifts and holds every gear like a million bucks.... so either it was built somewhat awhile back or i am just really really lucky so far, haha
                                  It will go to Goerend for all the goodies when it does shit.... But yes i do have a billet 3 disk Goerend converter, that was a huge difference over the stock converter
                                    Anyway got this on tonight and it is absolutely sick in the difference, cant wipe my smile off yet
                                    spools very nice yet, and is a freight train up top now instead of falling off..... egts never go above 1300
                                    and the sound is ridiculous sick
                                    so happy!!
                                      vid or it didnt happen!
                                        beachbum_jon
                                        nice, good job, what injectors and fueling mods do you have?
                                          DDP 140 sticks, #0 fuel plate, 4k governor springs
                                          edit, and timing is bumped to 16.5*
