  4. Anyone know a good mechanic shop?
46 Posts 20 Posters 1.6k Views
    TurboGTU
    have you had the low coolant light come on recently. could be the upper intake plennum/gasket (i'm assuming you have a 3100). something to check into at least. good luck.
    2006 Mazda 6s Grand Sport
      did she overheat it at all?
        its a 3.4L. No coolant light hasnt come on. the coolant level is normal. It hasnt overheated.
        • harmH Offline
          harmH Offline
          harm
          if it's cranking over with the ignition key, it's not the VATS. if the VATS isn't recognizing the resistor in your key, you'll get nothing at all when you turn the key to start, aside from a blinking anti-theft light.
          i've only seen one person successfully bypass their VATS - that's a nice write-up though, and looks like it would work if done correctly. Waste of time/energy unless your VATS wires snap somewhere though.. which happens a lot.
            You have obviously never installed remote starters for a living then... It takes a resistor and a relay and is not rocket science.
              Oh. God. That motor sucks.
              • SlowicaS Offline
                SlowicaS Offline
                Slowica
                no way, the 3.1 and 3.4s were great motors............
                  Yes it does. This is not my first run in with this pile
                  • SlowicaS Offline
                    SlowicaS Offline
                    Slowica
                    give me the year and i can run a quick check on alldata for you, see if theres any TSBs on it.
                      The 3400, this is the DOHC 3.4 liter................
                        umm... no 3.8 was a great motor.. 3.1 = nasty piston slap
                          slowica;298612 wrote:
                          give me the year and i can run a quick check on alldata for you, see if theres any tsbs on it.
                          1997
                            umm....the 60 degree V6s were very successful motors for GM...they hardly ever had problems(with the exception of the 3.4 DOHC). GMs problem has never been engines, its FWD trannies.
                            • SlowicaS Offline
                              SlowicaS Offline
                              Slowica
                              apparently my hint of sarcasm wasn't noticed lol
                              • harmH Offline
                                harmH Offline
                                harm
                                no, I definitely haven't. I'm not trying to say it's difficult. I just haven't seen many people do it right. I've fixed plenty of home-brewed attempts at soldering in resistors, wired-in keys.. just saying if he can still crank the engine over, the problem isn't VATS-related.
                                  I seemed to have fixed the car now. I changed the fuel filter which was nasty. Then last night I checked for spark and it was getting it. I pulled one plug and it was ok, but it was showing signs of wear. I pulled out another spark plug close to the oil fill cap and I found a pile of oil. the Plug was toast. So i pulled the next plug and it was even worse. When I had the oil changed the lube tech must have spilt oil into the spark plug hole. I replaced the front three plugs for now since i have to remove the intake mainifold to get to the rears.
                                  Anyways i went to start the car and still wouldnt start. It was still flooded. I finally got it started and it smoked to beat hell for 5 mins. It seems fine now, so later today I am replaceing the rest of the plugs and all the wires. Gayness
                                    Keep an eye on the spark plug wells, it could be a valve cover gasket.
                                      Pretty sure you can do the rear plugs with out pulling the intake manifold.
                                      • gsrEKG Offline
                                        gsrEKG Offline
                                        gsrEK
                                        not on the engine thats in the car, its a 3.4 DOHC. IIRC
                                        2009 Yamaha Zuma 125, gas HOG
                                        2008 Honda Fit daily
                                        A s2k
                                        1991 Honda civic DX Mint SOLD
                                        1988 Mitsubishi Mighty max
                                        > BlackEJ8;233529 wrote:
                                        • SlowicaS Offline
                                          SlowicaS Offline
                                          Slowica
                                          did plugs on one last year. what a fun time.
