  4. Anyone know a good mechanic shop?
46 Posts 20 Posters 1.8k Views
  • blackcherryTSiB Offline
    blackcherryTSi
    Rexwagon;298412 wrote:
    its a 1997. It does have one of those computer chips in the key but the anti theft light isnt flashing. It doesnt have remote start.
    is the chip in the key bad then maybe?
    1995 Honda Civic
      Slowica;298385 wrote:
      Ive had good experience with southpointe on 32nd. They don't screw you over with parts you don't need or jack up part prices.
      I brought the Talon there one time back in the day when I was having problems. They told me they couldn't fix it because it had too many missing and too many aftermarket parts.
      I lol'd.
        Yeah it could be it the VATS...
        get to it I know you are bored...
        http://vats.likeabigdog.com/
          Holy fuck. lol. Thanks though.
          I also tried using both keys for the ignition and it didnt change anything but I will check into that as well. I think I am going to replace the fuel preasure regulator. I dont think thats going to work, worth a shot.
            STOP THROWING PARTS AT IT. it doesnt sound anything like a fuel pressure regulator.
              word.....highly unlikely it is the FPR, and even with 20psi that thing is going to pop and fire
              take the cap off the schrader valve on the rail and open it for a second, if you have crisp pressure you are good
                Ok thanks, will try that then.
                  TurboGTU
                  have you had the low coolant light come on recently. could be the upper intake plennum/gasket (i'm assuming you have a 3100). something to check into at least. good luck.
                  2006 Mazda 6s Grand Sport
                    did she overheat it at all?
                      its a 3.4L. No coolant light hasnt come on. the coolant level is normal. It hasnt overheated.
                      • harmH Offline
                        harmH Offline
                        harm
                        if it's cranking over with the ignition key, it's not the VATS. if the VATS isn't recognizing the resistor in your key, you'll get nothing at all when you turn the key to start, aside from a blinking anti-theft light.
                        i've only seen one person successfully bypass their VATS - that's a nice write-up though, and looks like it would work if done correctly. Waste of time/energy unless your VATS wires snap somewhere though.. which happens a lot.
                          You have obviously never installed remote starters for a living then... It takes a resistor and a relay and is not rocket science.
                            Oh. God. That motor sucks.
                            • SlowicaS Offline
                              SlowicaS Offline
                              Slowica
                              no way, the 3.1 and 3.4s were great motors............
                                Yes it does. This is not my first run in with this pile
                                • SlowicaS Offline
                                  SlowicaS Offline
                                  Slowica
                                  give me the year and i can run a quick check on alldata for you, see if theres any TSBs on it.
                                    The 3400, this is the DOHC 3.4 liter................
                                      umm... no 3.8 was a great motor.. 3.1 = nasty piston slap
                                        slowica;298612 wrote:
                                        give me the year and i can run a quick check on alldata for you, see if theres any tsbs on it.
                                        1997
                                          umm....the 60 degree V6s were very successful motors for GM...they hardly ever had problems(with the exception of the 3.4 DOHC). GMs problem has never been engines, its FWD trannies.
