  4. Anyone know a good mechanic shop?
46 Posts 20 Posters 1.6k Views
    Yeah it could be it the VATS...
    get to it I know you are bored...
    http://vats.likeabigdog.com/
      Holy fuck. lol. Thanks though.
      I also tried using both keys for the ignition and it didnt change anything but I will check into that as well. I think I am going to replace the fuel preasure regulator. I dont think thats going to work, worth a shot.
        STOP THROWING PARTS AT IT. it doesnt sound anything like a fuel pressure regulator.
          word.....highly unlikely it is the FPR, and even with 20psi that thing is going to pop and fire
          take the cap off the schrader valve on the rail and open it for a second, if you have crisp pressure you are good
            Ok thanks, will try that then.
              TurboGTU
              have you had the low coolant light come on recently. could be the upper intake plennum/gasket (i'm assuming you have a 3100). something to check into at least. good luck.
              2006 Mazda 6s Grand Sport
                did she overheat it at all?
                  its a 3.4L. No coolant light hasnt come on. the coolant level is normal. It hasnt overheated.
                  • harmH Offline
                    harmH Offline
                    harm
                    if it's cranking over with the ignition key, it's not the VATS. if the VATS isn't recognizing the resistor in your key, you'll get nothing at all when you turn the key to start, aside from a blinking anti-theft light.
                    i've only seen one person successfully bypass their VATS - that's a nice write-up though, and looks like it would work if done correctly. Waste of time/energy unless your VATS wires snap somewhere though.. which happens a lot.
                      You have obviously never installed remote starters for a living then... It takes a resistor and a relay and is not rocket science.
                        Oh. God. That motor sucks.
                        • SlowicaS Offline
                          SlowicaS Offline
                          Slowica
                          no way, the 3.1 and 3.4s were great motors............
                            Yes it does. This is not my first run in with this pile
                            • SlowicaS Offline
                              SlowicaS Offline
                              Slowica
                              give me the year and i can run a quick check on alldata for you, see if theres any TSBs on it.
                                The 3400, this is the DOHC 3.4 liter................
                                  umm... no 3.8 was a great motor.. 3.1 = nasty piston slap
                                    slowica;298612 wrote:
                                    give me the year and i can run a quick check on alldata for you, see if theres any tsbs on it.
                                    1997
                                      umm....the 60 degree V6s were very successful motors for GM...they hardly ever had problems(with the exception of the 3.4 DOHC). GMs problem has never been engines, its FWD trannies.
                                      • SlowicaS Offline
                                        SlowicaS Offline
                                        Slowica
                                        apparently my hint of sarcasm wasn't noticed lol
                                        • harmH Offline
                                          harmH Offline
                                          harm
                                          no, I definitely haven't. I'm not trying to say it's difficult. I just haven't seen many people do it right. I've fixed plenty of home-brewed attempts at soldering in resistors, wired-in keys.. just saying if he can still crank the engine over, the problem isn't VATS-related.
