  4. Anyone know a good mechanic shop?
46 Posts 20 Posters 1.5k Views
    ^ good point... does it have autostart?
    • svxALS Offline
      svxALS Offline
      svxAL
      Darrels repair in north moorhead he is a super good guy and will fix only what needs to be. He only works on american cars and he is pretty cheap. very knowledgeable!
      94 Subaru SVX FWD
      subaru-svx.net
      1999 silverado
        Touche son. He has been my family mechanic for years and you are not kidding he really will only fix what you tell him to do. Place is fuckin BUSY tho.
        I can also vouch for Corey's, worked closely with Frank there on more than one occasion and he's one of the best.
          Coreys Car Care has my vote...Darrel's also has a good rep.
            talk to Christian over at Corey's Car Care
              blackcherryTSi;298391 wrote:
              question...... is it a newer monte carlo?.... my parents had one and my dad was dickin around with something and ended up tripping the anti theft and the car wouldnt start. so maybe you having the same issue? just an option
              its a 1997. It does have one of those computer chips in the key but the anti theft light isnt flashing. It doesnt have remote start.
              • blackcherryTSiB Offline
                blackcherryTSi
                is the chip in the key bad then maybe?
                1995 Honda Civic
                  Slowica;298385 wrote:
                  Ive had good experience with southpointe on 32nd. They don't screw you over with parts you don't need or jack up part prices.
                  I brought the Talon there one time back in the day when I was having problems. They told me they couldn't fix it because it had too many missing and too many aftermarket parts.
                  I lol'd.
                    Yeah it could be it the VATS...
                    get to it I know you are bored...
                    http://vats.likeabigdog.com/
                      Holy fuck. lol. Thanks though.
                      I also tried using both keys for the ignition and it didnt change anything but I will check into that as well. I think I am going to replace the fuel preasure regulator. I dont think thats going to work, worth a shot.
                        STOP THROWING PARTS AT IT. it doesnt sound anything like a fuel pressure regulator.
                          word.....highly unlikely it is the FPR, and even with 20psi that thing is going to pop and fire
                          take the cap off the schrader valve on the rail and open it for a second, if you have crisp pressure you are good
                            Ok thanks, will try that then.
                              TurboGTU
                              have you had the low coolant light come on recently. could be the upper intake plennum/gasket (i'm assuming you have a 3100). something to check into at least. good luck.
                              2006 Mazda 6s Grand Sport
                                did she overheat it at all?
                                  its a 3.4L. No coolant light hasnt come on. the coolant level is normal. It hasnt overheated.
                                  • harmH Offline
                                    harmH Offline
                                    harm
                                    if it's cranking over with the ignition key, it's not the VATS. if the VATS isn't recognizing the resistor in your key, you'll get nothing at all when you turn the key to start, aside from a blinking anti-theft light.
                                    i've only seen one person successfully bypass their VATS - that's a nice write-up though, and looks like it would work if done correctly. Waste of time/energy unless your VATS wires snap somewhere though.. which happens a lot.
                                      You have obviously never installed remote starters for a living then... It takes a resistor and a relay and is not rocket science.
                                        Oh. God. That motor sucks.
                                        • SlowicaS Offline
                                          SlowicaS Offline
                                          Slowica
                                          no way, the 3.1 and 3.4s were great motors............
