  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
  • 63vette6 Offline
    63vette6 Offline
    63vette
    z31;298246 wrote:
    The hammer in not on the bench? :icon_scratch:
    All the other hammers are on the bench... That one must have been on the floor.
    I have never seen that little thing before, his 4 pounder is preferred weapon.
    • XJHEADX Offline
      XJHEADX Offline
      Are you guys making fun of me again?? That hammer in the picture just happened to be the first I found. I did do a quick walk around the shop looking for my favorite 4lb'r, it's probably in the truck. I never did find it but did run across these.
      • z31Z Offline
        z31Z Offline
        z31
          That Estwing Framing Hammer is a fucking weapon. Those are the best hammers, hands down.
            their weight forward hammers suck they wreck everything
            • XJHEADX Offline
              XJHEADX Offline
              DaveH;260380 wrote:
              Looks like you better order up a wheelie bar kit... and a case of Depends.
              New tires showed up yesterday
              Old vs new, about the same width 11.75" on the ground.
                Starting to get some Man-sized tires I see. We should set them next to one of my 33's, would be interesting to see the difference.
                • 63vette6 Offline
                  63vette6 Offline
                  63vette
                  Racing on drag radials is like drifting an import without the control.. 🙂
                  • XJHEADX Offline
                    XJHEADX Offline
                    Notching the frame for new spring pockets.
                    • XJHEADX Offline
                      XJHEADX Offline
                      Got a little more done.
                      This is what the stock mount looks like. Large spring with perch on the outside of the frame-rail.
                      • XJHEADX Offline
                        XJHEADX Offline
                        And this is still called stock suspension. lol
                        • funky_monkey58F Offline
                          funky_monkey58
                          Looks stock to me.
                            Moving the spring in just gives you room for a bigger tire right?
                            • XJHEADX Offline
                              XJHEADX Offline
                              Yes, that is the only reason why I am doing it. I cannot go to a coil-over.
                              • XJHEADX Offline
                                XJHEADX Offline
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  New shocks finally showed up. Everything for the mini-tub is almost complete. Now I just need to order some new wheels to tuck the tires in some more..
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    Stripped everything off the bottom of the car and gave it a quick spray. Looks much nicer than flat black.
                                      Strange shocks this time?
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        Yep, they were quite a bit cheaper than a set of Afco's.
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Mini-tub is almost all complete. Just a little bit of the tubs are showing. I may switch the seat carpet to black. Haven't decided yet, whatcha think?
