  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
  • XJHEADX Offline
    XJHEADX Offline
    And this is still called stock suspension. lol
    • funky_monkey58F Offline
      funky_monkey58
      Looks stock to me.
        Moving the spring in just gives you room for a bigger tire right?
        • XJHEADX Offline
          XJHEADX Offline
          Yes, that is the only reason why I am doing it. I cannot go to a coil-over.
          • XJHEADX Offline
            XJHEADX Offline
            • XJHEADX Offline
              XJHEADX Offline
              New shocks finally showed up. Everything for the mini-tub is almost complete. Now I just need to order some new wheels to tuck the tires in some more..
              • XJHEADX Offline
                XJHEADX Offline
                Stripped everything off the bottom of the car and gave it a quick spray. Looks much nicer than flat black.
                  Strange shocks this time?
                  • XJHEADX Offline
                    XJHEADX Offline
                    Yep, they were quite a bit cheaper than a set of Afco's.
                    • XJHEADX Offline
                      XJHEADX Offline
                      Mini-tub is almost all complete. Just a little bit of the tubs are showing. I may switch the seat carpet to black. Haven't decided yet, whatcha think?
                        looks HACK!!
                        that carpet does look kind of out of place i guess, not that i would care
                        BTW i was thinking today, how extensive is your fire supression system on that? Just engine bay or multi zone
                        • XJHEADX Offline
                          XJHEADX Offline
                          Grr;305009 wrote:
                          looks HACK!!
                          Sad thing is I haven't installed it yet. It is going in this winter. It has 2 lines off the head. One will go to a 360* nozzle and the other will go to 2-180* nozzles. There are conflicting ides on where to mount them. I think they all should be in the engine bay. Some like one in car in front of you.
                            Better keep the carpet, otherwise you know someone at BIR will claim the interior isn't "finished" enough looking.
                            • XJHEADX Offline
                              XJHEADX Offline
                              Big things can come in small packages.
                                Those got shipped to the wrong place I believe! My grandpa is missing the sprayer heads for his new center pivot on his farm.
                                • ChristianC Offline
                                  ChristianC Offline
                                  Christian
                                  So are you going to be able to watch the corn gauge go down with those injectors?
                                  Playtime Performance
                                  06 F-150 Lariat
                                  • blackcherryTSiB Offline
                                    blackcherryTSi
                                    youve got enough there for TWO engines! haha
                                    1995 Honda Civic
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      I just finished up redoing the cold side piping with AL. also added another TIAL blow-off. Savings of 13.5, I had stainless steel.
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        When is that beast gonna hit the track? Or Dynotune first?
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Dynotune first,hopefully in a couple weeks. 1500+ as long as the headgaskets stay where they're are suppose to.
