  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
  • XJHEADX Offline
    XJHEADX Offline
    Mini-tub is almost all complete. Just a little bit of the tubs are showing. I may switch the seat carpet to black. Haven't decided yet, whatcha think?
      looks HACK!!
      that carpet does look kind of out of place i guess, not that i would care
      BTW i was thinking today, how extensive is your fire supression system on that? Just engine bay or multi zone
      • XJHEADX Offline
        XJHEADX Offline
        Grr;305009 wrote:
        looks HACK!!
        Sad thing is I haven't installed it yet. It is going in this winter. It has 2 lines off the head. One will go to a 360* nozzle and the other will go to 2-180* nozzles. There are conflicting ides on where to mount them. I think they all should be in the engine bay. Some like one in car in front of you.
          Better keep the carpet, otherwise you know someone at BIR will claim the interior isn't "finished" enough looking.
          • XJHEADX Offline
            XJHEADX Offline
            Big things can come in small packages.
              Those got shipped to the wrong place I believe! My grandpa is missing the sprayer heads for his new center pivot on his farm.
              • ChristianC Offline
                ChristianC Offline
                Christian
                So are you going to be able to watch the corn gauge go down with those injectors?
                Playtime Performance
                06 F-150 Lariat
                • blackcherryTSiB Offline
                  blackcherryTSi
                  youve got enough there for TWO engines! haha
                  1995 Honda Civic
                  • XJHEADX Offline
                    XJHEADX Offline
                    I just finished up redoing the cold side piping with AL. also added another TIAL blow-off. Savings of 13.5, I had stainless steel.
                    • z31Z Offline
                      z31Z Offline
                      z31
                      When is that beast gonna hit the track? Or Dynotune first?
                      • XJHEADX Offline
                        XJHEADX Offline
                        Dynotune first,hopefully in a couple weeks. 1500+ as long as the headgaskets stay where they're are suppose to.
                          After that, drive it like you stole it.
                          • z31Z Offline
                            z31Z Offline
                            z31
                            Are you gonna make the show and go?
                            • XJHEADX Offline
                              XJHEADX Offline
                              That's the plan.
                              • XJHEADX Offline
                                XJHEADX Offline
                                I should have enough fuel pump now. Just need to measure for the cable and order it up.
                                13.4 gallons per minute @ 100 psi
                                Crank trigger and mandrel installed.
                                  smart man, ive talked 4 people into those cable driven fuel pumps, they are simply awesome in every way
                                  • funky_monkey58F Offline
                                    funky_monkey58
                                    That sir, is one badass setup you have there!
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      Late night on the dyno last night. 36 psi spinning bad.
                                        funky_monkey58
                                        Time for a hub dyno?
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Made it to the dyno last Friday. I am having some issues. Anyways 32 psi we were at 146X rwhp then made a hit at 36 psi, Only picked up 20+ rwhp. Pushed through the convertor bad, wheel speed was only 145, should have been right around 180 or more.
                                          [ame]http://www.youtube.com/watch?v=hJelDz_XOQQ[/ame]
