  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 52.0k Views
  • XJHEADX Offline
    XJHEADX Offline
    Grr;305009 wrote:
    looks HACK!!
    that carpet does look kind of out of place i guess, not that i would care
    BTW i was thinking today, how extensive is your fire supression system on that? Just engine bay or multi zone
    Sad thing is I haven't installed it yet. It is going in this winter. It has 2 lines off the head. One will go to a 360* nozzle and the other will go to 2-180* nozzles. There are conflicting ides on where to mount them. I think they all should be in the engine bay. Some like one in car in front of you.
      Better keep the carpet, otherwise you know someone at BIR will claim the interior isn't "finished" enough looking.
      • XJHEADX Offline
        XJHEADX Offline
        Big things can come in small packages.
          Those got shipped to the wrong place I believe! My grandpa is missing the sprayer heads for his new center pivot on his farm.
          • ChristianC Offline
            ChristianC Offline
            Christian
            So are you going to be able to watch the corn gauge go down with those injectors?
            Playtime Performance
            06 F-150 Lariat
            • blackcherryTSiB Offline
              blackcherryTSi
              youve got enough there for TWO engines! haha
              1995 Honda Civic
              • XJHEADX Offline
                XJHEADX Offline
                I just finished up redoing the cold side piping with AL. also added another TIAL blow-off. Savings of 13.5, I had stainless steel.
                • z31Z Offline
                  z31Z Offline
                  z31
                  When is that beast gonna hit the track? Or Dynotune first?
                  • XJHEADX Offline
                    XJHEADX Offline
                    Dynotune first,hopefully in a couple weeks. 1500+ as long as the headgaskets stay where they're are suppose to.
                      After that, drive it like you stole it.
                      • z31Z Offline
                        z31Z Offline
                        z31
                        Are you gonna make the show and go?
                        • XJHEADX Offline
                          XJHEADX Offline
                          That's the plan.
                          • XJHEADX Offline
                            XJHEADX Offline
                            I should have enough fuel pump now. Just need to measure for the cable and order it up.
                            13.4 gallons per minute @ 100 psi
                            Crank trigger and mandrel installed.
                              smart man, ive talked 4 people into those cable driven fuel pumps, they are simply awesome in every way
                              • funky_monkey58F Offline
                                funky_monkey58
                                That sir, is one badass setup you have there!
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Late night on the dyno last night. 36 psi spinning bad.
                                    funky_monkey58
                                    Time for a hub dyno?
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      Made it to the dyno last Friday. I am having some issues. Anyways 32 psi we were at 146X rwhp then made a hit at 36 psi, Only picked up 20+ rwhp. Pushed through the convertor bad, wheel speed was only 145, should have been right around 180 or more.
                                      [ame]http://www.youtube.com/watch?v=hJelDz_XOQQ[/ame]
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        So anybody done a 25.3 before 😉
                                        • F Offline
                                          F Offline
                                          ForestGreen
                                          thats wicked!
