  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
    Strange shocks this time?
    XJHEAD;302814 wrote:
    New shocks finally showed up. Everything for the mini-tub is almost complete. Now I just need to order some new wheels to tuck the tires in some more..
    • XJHEADX Offline
      XJHEADX Offline
      Yep, they were quite a bit cheaper than a set of Afco's.
      • XJHEADX Offline
        XJHEADX Offline
        Mini-tub is almost all complete. Just a little bit of the tubs are showing. I may switch the seat carpet to black. Haven't decided yet, whatcha think?
          looks HACK!!
          that carpet does look kind of out of place i guess, not that i would care
          BTW i was thinking today, how extensive is your fire supression system on that? Just engine bay or multi zone
          • XJHEADX Offline
            XJHEADX Offline
            Grr;305009 wrote:
            looks HACK!!
            Sad thing is I haven't installed it yet. It is going in this winter. It has 2 lines off the head. One will go to a 360* nozzle and the other will go to 2-180* nozzles. There are conflicting ides on where to mount them. I think they all should be in the engine bay. Some like one in car in front of you.
              Better keep the carpet, otherwise you know someone at BIR will claim the interior isn't "finished" enough looking.
              • XJHEADX Offline
                XJHEADX Offline
                Big things can come in small packages.
                  Those got shipped to the wrong place I believe! My grandpa is missing the sprayer heads for his new center pivot on his farm.
                  • ChristianC Offline
                    ChristianC Offline
                    Christian
                    So are you going to be able to watch the corn gauge go down with those injectors?
                    Playtime Performance
                    06 F-150 Lariat
                    • blackcherryTSiB Offline
                      blackcherryTSi
                      youve got enough there for TWO engines! haha
                      1995 Honda Civic
                      • XJHEADX Offline
                        XJHEADX Offline
                        I just finished up redoing the cold side piping with AL. also added another TIAL blow-off. Savings of 13.5, I had stainless steel.
                        • z31Z Offline
                          z31Z Offline
                          z31
                          When is that beast gonna hit the track? Or Dynotune first?
                          • XJHEADX Offline
                            XJHEADX Offline
                            Dynotune first,hopefully in a couple weeks. 1500+ as long as the headgaskets stay where they're are suppose to.
                              After that, drive it like you stole it.
                              • z31Z Offline
                                z31Z Offline
                                z31
                                Are you gonna make the show and go?
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  That's the plan.
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    I should have enough fuel pump now. Just need to measure for the cable and order it up.
                                    13.4 gallons per minute @ 100 psi
                                    Crank trigger and mandrel installed.
                                      smart man, ive talked 4 people into those cable driven fuel pumps, they are simply awesome in every way
                                      • funky_monkey58F Offline
                                        funky_monkey58
                                        That sir, is one badass setup you have there!
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Late night on the dyno last night. 36 psi spinning bad.
